Results 1 to 10 of 13
Thread: few little niggles
    sheffield
    Default few little niggles
    so i picked up my car yesterday as i mentioned before i bought it from a salvage place and had it fixed up so i've been waiting for about 4 weeks for it.
    all in all it's a very very nice car but theres a couple of little bits i want to get sorted out.
    The temperature is showing --- unless it's raining or wet in which case it shows between minus 40 and 25, i checked the connection on the sensor and it seems ok should i try a new sensor?
    The interior light wont work at all not on door unlocking, door opening or with the button, i've tried replacing both bulbs and tried them in both ways so i'm not sure where to go from there
    the air vent on the offside has a couple of wonky horizontal bars, is it easy to fix this or should i try and get a replacement?
    I bought a spare alloy wheel as one was damaged but the new one has some white writing on, what can i use to get this off?
    good start i know, thanks in advance
    joss
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Glad your enjoying the new motor.
    I would try a new temperature sensor first and the vents can be bought singularly from VXL I believe, not sure on price though.
    Have you checked the fuses ref the internal lights?
    AG Super Resin Polish might shift the writing on your wheel? Best just to try a few things.
    HTH
    Apr 2006
    Just seen these in the For Sale section. CLICKY
    sheffield
    any idea which fuse i should check?
    sheffield
    anyone?
    Jun 2007
    Black Country
    might be just as quick to check every fuse in the fuse box mate, at least you will see if any others have gone too
    May 2008
    Tyneside
    All the interior lights are fed/controlled from the body control unit. This is tied in with the can-bus system. Check the fuse F7 (30A) for the body control unit in the passenger fusebox at the LH end of the dash (open passenger door for access). Are any interior lights working - boot, glovebox, cigarette lighter, vanity mirror, door lights? They are all controlled by the same unit. HTH
    Full Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    and even check in the rear where the roof loom ends, to check if the wireblock is acctached to the REC
    sheffield
    ah ok, yes all the rest of the lights are working, i'll try the fuse box in the boot, see if there is anything obvious in there
    sheffield
    if it is the fuse wouldn't other things be affected like the rest of the interior lights? can anyone suggest something else? either that or recommend a good vauxhall indy garage in sheffield?
  1. A few niggles
    By Cruize in forum Troubleshooting
    Last Post: 27th January 2012, 14:10
  2. A few little niggles
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 15th March 2011, 21:25
  3. Few niggles GSi 3.2 - Help!!!
    By del3.2 in forum Engine & Drivetrain
    Last Post: 3rd December 2010, 21:06
  4. more little niggles from the 3.2?
    By jamesr in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2008, 14:17
  5. A few niggles
    By v6boy in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2006, 20:50
