Thread: led / dash question
    cleethorpes
    Default led / dash question
    have been converting vectra2002's dash to blue...but am having trouble getting some parts out.
    1. the light unit...pressed the button under the light unit but stil seems tight in ?
    2. elec window switches...drivers and pasangers ?
    3. took the computer out and split it down to seeing two boards...whats the best way to go about spliting to put smd's in please ?
    4. sterio coltrols on the stearing wheel ?
    done the heater unit and buttons (heated seats and alarm)
    thanks in advance
    Regular Member Robbie69's Avatar
    PM KMAN, he's the man to ask.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Quote Originally Posted by diablo666 View Post
    thanks in advance
    1 there is a trick to getting the light control out, push the dial in and twist at the same time and then pull it out, same as a mk4 golf
    2 ele window buttons just pop out with a flat blade
    3 what display have you got?
    4 little splines at the back ( one on each side) then give it a pull
    milton keynes
    thanks in advance
    1. are you talking about the courtesy light? if so read my 'how to'
    2.small flat blade driver at the bottom of the whole thing, then just pops out.
    3.if you have the 2 boards apart , whats your problem?
    4. torx bit at the rear of controls , unscrew and prise out, if you have a half canbus its a nightmare re fitting
    Regular Member darby's Avatar
    www.NinjaUK.com
    thanks in advance
    1. Headlight switch to 'off', push it in and turn sidelights on, the unit should just pull out.
    2. Small screwdriver and a lot of care.
    3. Unscrew boards and desolder the two little wires. You'll know the ones I mean when you look at it. The unit comes apart and you can see the SMDs.
    4. There is a torx screw on the back of each spoke, undo it and prize the plastic part that houses the buttons off. Once out, the unit will unclip.
    HTH
    www.NinjaUK.com
    damn - beat me to it
    cleethorpes
    thanks everyone for the replys....it was the two wires that was worrying me on the computer display...striped it down and saw the two wires there and re-assembled it till i got some advice lol...with it not been my car i didn't want to break anything lol
  1. Dash lights & led conversion question
    By dieseldog in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2009, 00:53
  2. Dash Carcass Question...
    By Penfold101 in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2008, 22:19
  3. Dash Carcass Question...
    By Penfold101 in forum Styling
    Last Post: 22nd October 2008, 22:00
  4. Dash lights question?
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2007, 10:40
  5. Question on the Vectra dash
    By Aura XR in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2007, 20:25
