Thread: Blower Problem different to others
    Regular Member vockycdti's Avatar
    May 2007
    stoke
    Default Blower Problem different to others
    Hi guys can you help.....i have a problem with the blower it works for a minute or so then slows down and stops then doesn't work on any settings.i leave it for 5 minutes then it works again for a minute or soand the lights dimm on the control unit.... any ideas your help would be greatly received.
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    Sounds like the motor on it is seizing up, if you go under the bonnet pop out the pollen filter and try to turn the fan motor by hand and see if it rotates freely or is stiff to turn. that'll tell you for sure.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    yeah mate i would also say it needs a motor and a resisitor , best to always change them as a pair the motors can get rusty and stiff wich slows them down ...
    May 2007
    stoke
    ok guys thanks for your help i'll give it a look see if it turns freely.....is the pollen filter on the right hand side of the car as you look at it from the front.??
  1. Heating and blower problem?
    By shaine415 in forum Engine & Drivetrain
    Last Post: 26th February 2012, 17:07
  2. '02 GSI, heater/blower problem
    By RoddyKFC in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2011, 12:54
  3. Heater / blower problem
    By lacorbiere in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd March 2010, 14:24
  4. blower problem not qorking on 1,2,3 only 4
    By damadom in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2009, 10:05
  5. Blower Problem
    By danny_boy0111 in forum Bodywork & Interior
    Last Post: 24th January 2009, 17:51
