Thread: Door Mirror
    Hampshire
    Default Door Mirror
    I have to replace the electric door mirror on my daughters '54 plate Veccy.
    I have been through the 'How to' section and have a query, how does the inner plastic triangular fillet where the mirror screw are come off. Does the whole door card have to come off.
    Many thanks
    EJJ
    Administrator plasma's Avatar
    On the Forum
    408 Post(s)
    Engine : 150
    Mileage : 74000
    There are 2 clips on these, one upper and one lower below the door trim. You can remove it without removing the door card, but refitting is a tad tricky, you have to slide it back down and over the clip. Also theres a clip from the wiring loom onto it too.
    Hampshire
    Default Door mirror
    Plasma, Thanks for info, soon as when item arrives I will attempt.
    She was hit a glancing blow on the mirror in a narrow lane by ome idiot going to fast , she had stopped to let him past and he carried on past at speed.
    Then she tells me on Sun she is going away today, tried to get her to chase up replacement last Thurs, but it was " No I'll talk to Shaun and get him to get one" tame mechanic all he could say on Mon was try Main Dealer.
    Managed to get used from Ebay, guaranteed to fit '54 plate.
    Thanks again for your help.
    John
    Hampshire
    Default Door Mirror
    Found I could dismantle the mirror and only replace the damaged parts.
    This was mainly the black plastic 'mirror surround' as the rest was OK.
    Had to warm up plastic lugs to remove surrounds from both mirrors, and using blowtorch to heat 6" nail in mole grips used this to reform the rivets on the replaced part.
    Original mirror back clipped back on OK as there was no damage to fitting clips.
    Took about 1 hour, including 'thinking time'.
    Daughter is well chuffed, especially as I washed her car as well.
    John
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by EJJ150847 View Post
    John
    Your too soft mate glad its all sorted been hit a few times by old grannies and they just burn off like nothings happened
  1. door mirror
    By dustydes in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2012, 14:42
  2. Door Mirror Help
    By Elite Estate in forum Bodywork & Interior
    Last Post: 11th November 2008, 20:19
  3. Door Mirror Help Please
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2006, 21:46
