Thread: brake torx bits
    Nov 2005
    newcastle upon tyne
    Default brake torx bits
    hi all does anyone know the torx bit size that holds front brake caliper in place on a 2002 veccy 1.8 i went to do job today & there it was not allen key bolts but torx bit type so can anyone please advise coz wife is going to leave if i dont get rid of the annoying squeeling
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    You putting copper grease of the BACKS of the pads and sliding surfaces?
    Sorry, don't know the torx bit size.
    Nov 2005
    newcastle upon tyne
    yip ive greased all sliding parts & back of pads squeeking still there
    Dont know the size, but do know they are held on with loktight..make sure when you get the right size, the torx is of a good quality..(changed my discs foe drilled and grooved)
    Nicking Ya Dinner.
    I think he has warped disc somewhere on the car AF, from what he says in his other post it sounds like an intermittant rubbing causing the squeak, that or a bearing or bush is wearing.
    ive got a set of new fronts at home..they came off a vec-b, but they fit ours..
    Quote Originally Posted by stevietiger
    There are two fixing's steve..when I dismantled the GSi's brakes it had Torx fixings and 7mm allen's, that were hidden behind the plastic caps..The torx were for holding the caliper together and must never be undone. These bolts are stretch bolts and will not give the same clamping force once disturbed..
    The 7mm allen one's are the one's to remove to get access to the pads..
    Nov 2005
    newcastle upon tyne
    ok thanks for that
  1. Torx screws!
    By larrysSRI in forum Bodywork & Interior
    Last Post: 19th April 2012, 15:57
  2. which torx
    By marc vectra sri in forum Bodywork & Interior
    Last Post: 28th September 2011, 01:56
  3. cheap torx set.
    By jimmyred in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2011, 21:54
  4. torx size ????
    By anr_n_vec in forum Engine & Drivetrain
    Last Post: 23rd September 2010, 21:35
  5. Torx size for brake caliper
    By ninja2111 in forum Vectra C / Signum Troubleshooting
    Last Post: 12th May 2008, 20:15
what number torx socket for brake caliper www.vectra-c.com
what size star socket for corsa c front brake caliper
