Results 1 to 10 of 17
Thread: towbar will it fit?
    Regular Member xyy81t's Avatar
    Banbury
    Default towbar will it fit?
    it's off a saloon and my veccy is a hatch would have thought it would but need to be sure!
    cheers
    http://cgi.ebay.co.uk/Vauxhall-Vectr...|39:1|240:1318
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It looks the same as my Hatchback version.
    Electrics? - what's your plan?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Unless it had the plates to go inside the boot i would avoid
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    They would be easy to put together though, as they're only bits of flat plate to spread the loads a bit.
    Banbury
    Quote Originally Posted by Ste View Post
    well i'd have to buy an electrics kit separatly
    what are those then? i haven't really researched it does it not just bolt onto the chassis?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    The bolts go through the chassis and up into the boot floor. The plates go on the boot floor to spead the weight
    Banbury
    ok i assume the holes will already be in my chassis? sounds as though the plates will be easy enough to fabricate. if thats all they are.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    The holes have to be drilled but there are dimples on the boot floor under the sound deadning
    You'd also need high tensile sleeving to go into the chassis leg to stop it collapsing
    Banbury
    hmmmm ok and would the other side of the chassis underneath the car need drilling too? if so do you know if thats marked also?
    sounds like you've done it before!
    Ashington, Northumberland
    Well make sure you fit it correctly because they are part of the MOT test now
  1. TowBar
    By steve-wolves in forum General Chat
    Last Post: 8th April 2011, 18:08
  2. towbar
    Last Post: 17th March 2011, 10:49
  3. Which Towbar?
    By humphshumphs in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2010, 21:39
  4. Towbar help please
    By Robclowes in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2008, 16:56
  5. towbar help
    Last Post: 12th April 2008, 23:11
