Thread: How big is the job of fitting new front springs
    Kingston Upon Hull
    Default How big is the job of fitting new front springs
    Hi as above is it a big job and do you need any special tools apart from jack/ spanners hammer etc
    Thanks Jacko
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    theres made a how2 on that look there
    Mileage : 000
    You will need a spring compressor, and a spanner that will fit over the nut on the top of the strut that holds the plate in place when the spring is realeased. It needs to be a deep ring spanner. If you are not too sure how to change the coil springs it is best to get someonr to do it for you. If you do a search, you will find a "how to" for changing the front springs.
    Try here.
    Kingston Upon Hull
    Thanks for the help i have just read the how to post and thank you to the person that wrote it
    Jacko
  1. Anyone near Telford fancy fitting some front shocks/springs?
    By rob1981 in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2013, 19:07
  2. fitting new springs
    By redross555 in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2011, 21:21
  3. fitting new springs
    By rickeys16v in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 15:17
  4. Fitting springs
    By kns in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2009, 19:10
