Results 1 to 10 of 26
Thread: Please help..2.2 Direct
    Jan 2008
    Preston England
    Default Please help..2.2 Direct
    Hi everyone, I will apologise in advance if i waffle on a bit. My 05 Vectra 2.2 Direct seems to have given up the ghost, I would be grateful for any help/advice.
    I noticed a few weeks ago that on idle it was running slightly lumpy, but nothing major. Yesterday, I had just got off motorway, crawled in traffic for 15 mins, then whilst pulling away from traffic lights, power lost and EML came on ! I stopped, re-started and then all seemed fine for 5 mins, then same again. This time, I was unable to start without EML on. I managed to limp home with v little power.
    First thing I did was change plugs..no change, in fact the spanner light is now on but no EML??. (I noticed that whilst limping home, if I turned ignition 0ff/on then it wud tick over without any warning lights, slight pressure on throttle and engine seems to run on 3 cylinders before EML came on then would run smooth albeit with little power). the missfire was just like a plug lead wasnt firing, so maybe coil pack im thinking??. Had plugs out again, 3 are perfect colour, but the one on drivers' side is sooty.
    I am aware of the fuel pump/regulator problems also, I just dont know where to go with this...... sorry for waffling Guys, any help would be gratefully received
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    Hello,
    I would say coil pack or injector!! I would possibly be more inclined to try the coil pack first, although a sooty spark plug could mean that it is sparking but getting no combustion which would lead me to the injector. HTH
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Sorry mate, thats sounds like the High Pressure Fuel Pump problem as per Watchdog. It will gradually get worse unitl its undrivable.
    Exactly the same situation and symptoms with mine that wents 2 weeks ago.
    A trip to your dealers and stick it on Tech2 should confirm and then plead for some assistance from VXL with the cost of repair!
    Quote Originally Posted by BigP View Post
    lot's of info should you wish to try a search .................
    Jan 2008
    Preston England
    Thanks guys, I just cant understand why one plug should be sooty??..I've just bought a used coil pack , and it doesnt make any difference ! Ive located a second hand pump, does anyone know if its a DIY job?
    Warton
    Vehicle : Insignia
    Year : 2010
    Mileage : 26000
    Quote Originally Posted by DAVEYBOY View Post
    I dont think you can just swap it mate, I beleive it has to be tech2'd out and the new on tech2'd back in. In effect they are paired with the car!!
    Someone may correct me though!
    Jan 2008
    Preston England
    Please can anyone confirm whether it is possible to fit the high pressure fuel pump myself? and how difficult it may be.
    Apr 2006
    According to my invoice they recorded Tech2 fault P1191 Fuel pressure system malfunction. P0302 Cylinder 2 misfire detected. Replacement of HPF pump required.
    So I'm guessing because of how the direct injection system works when the pump starts to fail it fails on certain cylinders first.
    Sorry, don't know if its DIYable.
    Jan 2008
    Preston England
    Thanks for that..I've just unplugged the pressure regulator, both EMI and spanner light went off, and engine seemed to run ok. took it for a test drive, full power,although slightly lumpy at times. On return EMI came on but still running ok?? now im even more confused...anyone??
    Apr 2006
    I believe the two problems are interlinked. From what I've heard/read, most of the time dealers have replaced both parts when this problems occurs.
    Have a search about on here for more info mate, there are quite a few threads about it.
  1. I think my 2.2 direct has too much oil in it....
    By Knuckle in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2011, 15:18
  2. vectra 2.2 direct/non direct
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2009, 00:05
  3. 2.2 Direct mpg normally this bad?
    By Marc C in forum Engine & Drivetrain
    Last Post: 9th August 2008, 12:46
  4. 2.2 Direct 16v
    By cdms811 in forum Petrol Engine related
    Last Post: 12th December 2007, 00:55
  5. 2.2 Direct
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 20:50
