Results 1 to 10 of 11
Thread: Will the problems ever end??? Any advice welcome!!
    UK
    Default Will the problems ever end??? Any advice welcome!!
    My car is a 2006 56reg vectra 1.9cdti 150 auto elite estate
    Since buying the car in 2007 i've had a new gearbox in early 2008, a new inlet manifold in summer 2008 (swirl valve problem i think) + a new air flow sensor and had the high pressure diesel pump overhauled.
    I've just got the car back after another stretch in the garage this time having a new diesel partical filter in the exhaust at great expense and its still not right.
    The new DPF has fixed the main problem as it was blocked sold and the car would not even start but the car still has a lack of power before the turbo kicks in. It had this problem before the car went in and the garage also commented on it. They said there is an error code (air leak in the inlet) but they cant find a air leak. They thought the wastegate was sticking so they cleaned that up but no improvement.
    From the advice on here i've cleaned the EGR+solinoid and cleaned the boost sensor which were both seriously black but there was only a slight improvement.
    From time to time I will get the spanner light when I first cold start in the morning but then it goes out after 500yds (the car starts fine).
    Any advice welcome, thanks Andy
    Belfast
    Trade it in for a petrol.
    UK
    Wish i'd got a petrol now mate, but i've still got 18months finance left to pay on this one. My old 2ltr dti did 234k with only general maintainence and a few air flow meters so I naturaly went for another vx diesel.
    Sorry to hear that m8, petrol this way also but hope it's sorted for you soon ..............
    UK
    Just tryed unplugging the connector on the egr valve and low down power has improved but obviously get a spanner light.
    Plugged it back in and it's crap again, does this mean anything???
    Belfast
    You can't unplug or block the EGR on the CDTi - it'll always throw the EML and most of the time will go in to limp mode.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    TRy your vacuum actuattors/solenoid ,s. take the hose off of the unit and try to detect some suction , only 0.6 bar when working normally (just wet finger to test )if nothing found reverse test to other hose
    If nothing detected suspect actuattor/solenoidi s faulty very common fault which will not show up on a tech 2, similarly check all vacuum hose are correctly positioned they often get reversed by people that dont know what there doing..
    UK
    Quote Originally Posted by bobssignum View Post
    where about is the actuator?
    UK
    Just did the airbox mod while I was under the bonnet and gave my air flow meter a clean. No difference there but it was worth doing while my hands were dirty.
    Engine : 2.0DTi
    Mileage : 73350
    Himate just put a request out for some pics for you, to show you where to look for your actuattors/solenoid location.s seeing as i have a dti i dont have the pics to hand
  1. Tracking problems, advice please...
    By sheepish in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2012, 22:43
  2. few problems n need some advice plz ta
    By rick_2.2 dti in forum Engine & Drivetrain
    Last Post: 16th August 2012, 23:30
  3. Thermostat and other problems maybe? Advice please!
    By daz1409 in forum Engine & Drivetrain
    Last Post: 3rd June 2012, 22:48
  4. Problems already...advice please!
    By Davies20 in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 15:25
  5. pinking problems?? advice please
    By dhallett1 in forum Engine & Drivetrain
    Last Post: 9th May 2009, 22:33
