Hi,
Recieved my first vectra a few months ago, a 1.8 SXI 2004 (53 plate). Brilliant car but am having some little problems!
1) Central Locking - Already bumped a thread regarding this but thought i'd add it in this thread anyway. My main key unlocks the drivers door from quite a distance very happily but will only open all the doors (i.e the second press) only if i am close to the car OR if i wait 5-10seconds. Tried new battery reading 3.3v with no difference. Any opinions?
2) Spare Key Not Working - Tried it the other day to see if the same central locking problem occured, but instead the key wouldnt even open the doors! Changed the battery and same problem. I also tried to resync but opening the door and placing key in ignition but yet again nothing happened. LED lights up perfectly BUT I can't actually see the transponder chip in the key? My understanding is the chip should be in the keyblade portion when seperated, but theres nothing there in that indent, and more surprisingly, theres also nothing there in my main key which works perfectly! Any ideas on where it is, or how to get the spare working would be appreciated!
3) Both front windows are very intermittant. I believe this is caused by the switches, and im guessing I will need to clean all 3 switches. Any tips on removing them? I take it battery does not need to be disconnected?
Many thanks in advance!
