Page 1 of 9 123 ... LastLast
Results 1 to 10 of 85
Thread: Y30DT again
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default Y30DT again
    I think the fuel pump is giving up now.
    When the engine is warm it starts fine-ish. When cold it takes a while longer but starts with hardly any cough.
    HELP!!!!!!!!!!!!!!!!!!!!
    If it is the fuel pump, then it is likely the fault is present at all times
    Given the problem only occurs from cold start then it may be :
    glow plugs
    fuel filter
    exhaust system
    I would start with the easy ones
    The exhaust system should be checked for failed baffles and cat in full working order
    If the fuel filter is over 12 months old then replace that
    Finally have the glow plugs inspected (or replaced as they will need to come out)
    If the fuel filter is suspect then that will cost a few bob!
    I wouldn't consider this until every other avenue has been considered
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I had quite a missfire accelerating uphill with half throttle.
    Wouldn't I get a fault code for the glowplugs? I'm having serious EGR issues right now, waiting for it to arrive from the UK.
    The fuel filter is rather new. It's had a service at 242.000km.
    How can I check the exhaust?
    If the EGR is faulty then you will need to wait for this to be replaced
    That also explains my suspicions on the exhaust sytsem, as the EGR forms part of that
    Checking the exhaust is quite easy
    With the car cold,on a ramp simply bang the exhaust chambers and listen for any sounds
    There should not be any
    If you can hear any then it is highly likely the baffles have collapsed
    Full Member Big Sig's Avatar
    I can't remember, did you have injector issues? I have read reports of injector problems giving misfire like symptoms.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    The car does sound louder than it did before...
    I do have misfire like problems. I've had that since the EGR gave up on life All got worse when I added some injector cleaner in the fuel tank
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    That's what it does when it's parked for 4 hours.
    http://www.shrani.si/?2L/13F/3U9JIXPE/23032009237.mp4
    Fuel draining back to the tank?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I thought only DTi's have that problem
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Morning startups are getting quite difficult. When it starts, the engine shakes but drops to normal idle like it should. If I release the brake pedal it kicks into high idle and the engine shakes again for a moment (the higs idle is because of limp mode caused by faulty EGR). When I drive of it seems fine. After driving, what could be no more than 1 mile it starts misfiring under constant throttle at about 1500rpm or so (it's fine if I accelerate). Lately that's gotten even worse, for example when going uphill it starts coughing, misfiring (when doing that it smokes gray-ish) and if I accelerate it's the same if not worse. So all I can do is wait for it to stop coughing. All that major misfiring (going uphill) happens when the car is NOT in limp mode. When in limp mode it can misfire on the motorway at 1500rpm too.
    Under acceleration from low revs there is a wierd diesel clatter
  1. Why why why y30dt.....
    By martyngell in forum Y & Z30DT Specific
    Last Post: 31st May 2012, 14:04
  2. Y30DT - so is this the MAP sensor?
    By gtr1000 in forum Y & Z30DT Specific
    Last Post: 1st January 2012, 18:58
  3. y30dt egr
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2011, 08:43
  4. y30dt engine
    Last Post: 10th November 2008, 16:53
code defaut p1235 opel vectra c
opel fehlercode p1235
opel p1235
Signum Guide vane control
p1235 opel vectra
Signum p1235 fault code
y30dt engine fallo 1235
Opel DTC P1235-63
P 1235 fehlercode
opel signum guide vane control
P1235 opel
P1235 vauxhall remedy
Vectra code p1235
y30dt guide vain rod position.
error p1235-03 opel
y30dt egr
guide vane control rod position sensor
Fault code 1235 3.0 v6 d vauxhall
code default p01235 vectra c
code defaut opel vectra c p1235
blad p1235 vectra c
Y30DT injectors positions
Tags for this Thread
