Results 1 to 2 of 2
Thread: Swirl valve actuator
    scotland
    Default Swirl valve actuator
    HI all,
    Getting the inlet manifold replaced this saturday, question i have is it recommended to replace the swirl valve actuator at the same time?
    Oct 2007
    estonia
    if you have the fault P1109 - swirl valve stuck stored in ecu then it means your swirls have been stuck and that might have caused the swirl actuator internal damages. In that case it is recomended to replace the actuator.
    If there is not P1109 stored and you have the loose swirl flap bar on intake manifold then probably the swirl actuator is ok and you do not have to replace it.
  1. Swirl valve actuator bar
    By Big Si in forum Engine & Drivetrain
    Last Post: 2nd February 2012, 08:34
  2. Swirl valve actuator--Connection Bar
    By chrisgettings in forum Diesel Engine related
    Last Post: 27th September 2011, 19:57
  3. Connection between swirl valve and the actuator
    By genesisfm in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2011, 19:58
  4. swirl valve actuator
    By wirrallad in forum Engine & Drivetrain
    Last Post: 4th August 2009, 19:54
  5. Swirl valve actuator
    By Tigger in forum Engine & Drivetrain
    Last Post: 26th July 2009, 22:26
