Results 1 to 10 of 22
Thread: 2.2 direct egr
    norn iron
    Default 2.2 direct egr
    Really fancy cleaning my egr and been looking for some advice. All i can find is info on the non-direct which looks straight forward. the little info i could gather states that the direct's egr is water cooled, is this correct, dont want to start into this without a bit of backup
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    Water cooled it is mate, when you pop it off your going to have to drain the system before hand.
    norn iron
    Thanks for the reply, any idea where i might get pictures of location, how many and what type of bolts hold it on, how much coolant will i loose. sorry for all the questions but im a wee bit scared
    Vehicle : SRi
    Mileage : 110000
    The EGR is bolted onto the battery end of the lump, I'd imagine there are 2 possibly 3 bolts holding it on. As its quite a bit down the lump i'd say your going to lose quite a bit of coolant. There is a drain plug on the bottom of your rad. Are you having probs with it or something, TBH if your not having any probs I would just leave it.
    This is my EGR above the arrow (forget about the arrow it was from a different thread) the barrel shaped thing. Yours is in the same place. HTH
    norn iron
    i think its just this site mate, reading bout vectras all the time and peoples problems i think is making me paranoid, egr is not giving me any bother i just thought giving it a clean would keep it working correctly. i might stay away from this site for a while before i do some damage
    Vehicle : SRi
    Mileage : 110000
    Quote Originally Posted by deg View Post
    That's the dirty diesels mate, don't get me wrong, ours can fail but are not as troublesome as the sooty boys. VX fix by the way is just to get rid of it and tech 2 it out of the car, there not needed for uk MOT.
    norn iron
    cheers, think you have saved me a bit of bother,
    what could i do instead
    Vehicle : SRi
    Mileage : 110000
    No worries.
    Interesting reading, is that a fact regarding the ERG on the Direct 2.2?
    I also do not have a problem but handy to know should things play up. Having read about blanking them of but leaving the unit conected what are your thoughts Mr Rush? Cheers .........
    Vehicle : SRi
    Mileage : 110000
    With the none direct 2.2, just blanking them off but keeping them hooked up electrically is a tried and trusted thing. With the direct however I'm not to sure as its water cooled, if the blanking plate stops the water flow then I would have thought that wouldn't be a good thing. If Benny catches this thread he'll know for sure. But as said, the EGR is only needed to pass emissions from the factory. Once it leaves the factory its not needed and not even be an after thought come MOT time.
  1. I think my 2.2 direct has too much oil in it....
    By Knuckle in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2011, 15:18
  2. vectra 2.2 direct/non direct
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2009, 00:05
  3. 2.2 Direct mpg normally this bad?
    By Marc C in forum Engine & Drivetrain
    Last Post: 9th August 2008, 12:46
  4. 2.2 Direct 16v
    By cdms811 in forum Petrol Engine related
    Last Post: 12th December 2007, 00:55
  5. 2.2 Direct
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 20:50
