Thread: symbol in dash display
    Regular Member Swatty's Avatar
    Jul 2006
    greenock
    Default symbol in dash display
    Could someone check their manual for me please, needs to be for pre-face (03 GSi). I have filed my manual somewhere safe and its only new owners manuals on the vaux site.
    I’m getting the symbol below when I turn the engine off (does not appear during start-up or when running).
    Many TAs
    Forgot to say - Checked Brake Fluid level and all pads and everything is fine
    Mileage : 000
    This is what the book says.
    Brake system control indicator.
    The control indicator lights when the ignition is swithched on, if the handbrake is applied or it the brake fluid or clutch fluid level is too low.
    Regular Member Baz07's Avatar
    Lancashire
    Just going to say that Ed, must type faster..
    Jul 2006
    greenock
    Thanks Ed/Baz,
    I saw that in the new manuals but it was a different symbol (solid line outside rather than broken).
    I will try with the handbrake off
    Jul 2006
    greenock
    just tried stopping the engine hanbreak off and symbol still comes on (and the level of the brake fluid is spot on). I guess the level sensor could be u/s - one for when it stops raining.
    Ed, is there a separate clutch fluid top-up bottle
    Regular Member scottymartinXPSRI's Avatar
    fife
    i think its your brake wear indicator comes on when the pads are getting low. HTH
    Jul 2006
    greenock
    Hi Scotty, the pads looked as though they had pleanty of life in them (will look closer).
    fife
    check the wear indicators to see if there damaged or worn if the pads are ok. had the same sort of thing with my golf the wear indicators had worn but still had plenty of material on the pad.
    WGAF#5
    can also be bought on by the handbrake switch if faulty
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    i had this and it was a dodgy sensor on the front pass side caliper.
  1. Symbol on dash????????
    By dannyjpuk in forum Vectra C / Signum Troubleshooting
    Last Post: 13th December 2011, 15:48
  2. Symbol lit on dash
    By MARKPRIOR in forum Diesel Engine related
    Last Post: 2nd February 2011, 14:31
  3. dash symbol
    By Dwabo in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2010, 13:29
  4. dash symbol?
    By twaiter in forum Suspension, Wheels & Brakes
    Last Post: 16th March 2010, 23:55
  5. Symbol on the Dash
    By D-S-Dave in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2006, 20:00
