Results 1 to 10 of 26
Thread: droning from the front end....
    Regular Member markvec's Avatar
    livingston
    Default droning from the front end....
    .... at speed 10mph plus, not the engine cause its happening when i coast also and the revs drop, sound a bit like land rover tyres but way louder, cant feel anything through the steering wheel, any ideas I`m
    its a 04 sxi 1.8
    cheers
    Newcastle under Lyme
    Wheel bearing
    Sounds like a very loud hummin noise. I had it in the rear of my old old clio
    livingston
    any ideas of cost at a stealers to fix them... I`m skint ... it`s just passed an mot...
    Shouldnt have passed an mot if its that bad. Mine failed but it was at the point of seizing completely if I remember right. If its the front I think its a full hub jobby. May be proven wrong though.
    Regular Member KSD's Avatar
    Aug 2007
    Cupar, Fife
    I had a Clio with the same noise and it WAS the wheel bearing. Seems like its gone or going on the Vex too. It will get progressively louder with time if you keep driving it due to it breaking down.
    The clio was £50 and a really easy job. Its basically a set of ball bearings in cylindrical hollow tube and when they go the ball bearings crush, this then means tehre are less ball bearings doing the same job and doesnt take long for them to go after. When the all crush or tehre isnt enough to do the job they start wo weld themselves together and the wheel siezes which then means you get flat spots in the wheel due to dragging it and ultimately the wheel will blow
    livingston
    cheers peeps will get them checked asp
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Quote Originally Posted by JSYSH466Y View Post
    cars can pass an mot with a noisey bearing, but if it really bad they can addvise it, or fail it if it has excesive play,
    the bearings are £160 from the parts counter, dont know what they charge to fit, but if you can do some mechanical work it not to bad to do
    Quote Originally Posted by glynn View Post
    Good to know. Guessing for that price it is the full hub
  1. Droning noise from the front offside
    By sheepish in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2011, 22:22
  2. Droning noise from front - not bearing
    By Marc 100 in forum Suspension, Wheels & Brakes
    Last Post: 31st March 2011, 22:11
  3. Droning front brakes
    By bygumlad in forum Suspension, Wheels & Brakes
    Last Post: 23rd April 2009, 08:15
  4. Droning from front end
    By gtr1000 in forum Suspension, Wheels & Brakes
    Last Post: 23rd November 2008, 11:34
  5. Droning sound from front near side
    By Dio in forum Suspension, Wheels & Brakes
    Last Post: 18th April 2008, 00:07
