Results 1 to 10 of 11
Thread: Spanner Light
    Regular Member denzo's Avatar
    Runcorn
    Default Spanner Light
    Had the Spanner Light come on today (Car with Spanner through it)
    Just as I was beginning to go crazy, I stopped the car, got in again and restarted the engine ... no sign of the car and spanner light
    I guess it must have tripped on and fixed itself
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    I've had this a couple of times on the motorway when resuming the cruise control. Cleared once engine switched off.
    Nothing to worry about, probably just a gremlin.
    Nicking Ya Dinner.
    Quote Originally Posted by denzo
    Petrol or Diesel?
    If it's a petrol engine it will most likely be the thingymajig that I cant think of the name of right now needs cleaning, think carb, its the metal unit that mixes air and fuel between the air meter and the rocker cover, you need to undo the four torx screws and disconnect the water flow pipes, clean the bottom of it with carb cleaner all around the butterfly etc until its clean, also the pipe at the rear which goes to the rocker cover, clean that thoroughly and make sure the rubber pipe isn't blocked.
    Runcorn
    Hi
    It's a diesel CDTi (150bhp) .. I thought it may have been an indicator to drain the fuel filter of water ... shouldn't be any water in there though as I only use Shell Diesel Extra.
    Glad it has gone out though
    Jan 2006
    Dalriada
    its the engine management light mate, may be advisable to get it checked
    Get the codes read..with these canbus system's it could be any one of a thousand error's.. You fly blind until you know what's upset it..
    Nicking Ya Dinner.
    Ah, in thaa case I'm sorry I cant help out.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The old manual does state though that the light coming on for a short time and then going out is of no concern. I wouldn't worry about, unless it comes on again and stays on.
    BTW all diesels needs to have the water drained out occasionally from the fuel / water separator / filter. It is nothing to do with the brand of fuel used.
    Runcorn
    Light has definately gone out ... it came on when the missus was driving with me in the back with the baby. We stopped, I took over and drove following removing the keys and me restarting the engine ... thankfully no light on and the car is driving tickety boo
    Nicking Ya Dinner.
    It probably will return sometime in the next few mths, as it says in the book if it comes on and goes out dont worry.
    If it's the same system as a DTi, the fuel filter is easy to drain, just a knurled plastic nut at the bottom of the filter body, dont drain it too much or you risk an airblock and she wont start without a lot of prompting, samething if you replace the filter, have some spare derv to top the filter body back up before trying to start it again, might just need a new filter, I think 20k is the replace interval.
    By Shadrack in forum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
