Thread: condensation in oil
    Cleveland
    Default condensation in oil
    hiya all,
    Been having a problem with my 2.2 signum direct for a while now, and need to try and sort it.
    As my car is left on the drive all the time and i only drive short (10-15m) journeys i am getting sludge in my oil.
    And its blocking the crankcase pressure valve (pipe comes from rocker via valve to inlet manifold).
    Which at the moment i have to remove every week and remove all the sludge from it.
    So what would happen if i removed the valve altogether and replaced it with a normal through pipe, as i think the valve is just making it worse.
    Will the small amount of moisture that gets through do any damage else where (like cat).
    Its not coming from the coolant, as i have no loss.
    cheers for any help
    scott
    Regular Member barkzz's Avatar
    Are you sure the head gasket hasnt gone? Hence the crap in the oil?
    Full Member
    Bristol
    Short Jorneys will cause this. I don't know if its fitted to your but on vectra B 20ltr you could buy a breather kit for the engine from VX to stop this.
    Regular Member mattolly86's Avatar
    oxfordshire
    easiest way go for 25mile drive
    Jan 2006
    Skynet HQ EMEC#5
    I've recently had to clean this out of the rubber hoses going from the cam cover to the throttle body.
    It's because your engine isn't getting warmed up enough on your journey.
    Mine is due to my thermostat possibly stuck open, which is letting the engine run too cool.
    Quote Originally Posted by sb1uk View Post
    Did this one on mine & stopped it, also engine cutting out on low revs cured the problem not sure on the 'C' hth ......................
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Had the same on my old 2.2 Direct. IIRC VXL recommend changing the oil more often when driving fairly short journeys to help with problems like this.
  1. Afl got condensation them?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2012, 17:14
  2. Condensation
    By Mark2.2 in forum Bodywork & Interior
    Last Post: 3rd January 2012, 19:15
  3. Condensation within the car
    By gaz4d in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2010, 23:49
  4. condensation
    Last Post: 1st January 2010, 14:06
  5. Condensation
    By integrale in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2007, 11:21
