Results 1 to 10 of 26
Thread: Outside Tempertaure Gauge
    Regular Member CGSRI's Avatar
    Hertfordshire
    Default Outside Tempertaure Gauge
    Just piked up my new car. An 06 SRI CDTI 150.
    The outside temp guage on the middle display shows --/- is this a fault or do I need to press something to activate?
    The dealer had the front bumber resprayed so might have to have taken this off to do and i've read that sometimes sensors pack up?
    I know it's not a major issue but would be nice to know.
    Thanks in advance.
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    yep sensor is behind front bumper, probably forgot to reconnect wires.
    Hertfordshire
    Quote Originally Posted by Gr4eme View Post
    Simple fix? Something I can do myself?
    Quote Originally Posted by CGSRI View Post
    See if there's a dangly bit somewhere in front/behind you should see it ....
    Hertfordshire
    Can anyone give me some in depth instructions on how to reconnect and where to find it as I don't want to start ripping my new pride and joy to bits!
    ie. Do I need to remove grille etc and how to go about?
    Thanks.
    Surrey
    Isn't it clipped to the grill at the bottom or at least that is where I thought I remember seeing it?
    Go and have a look underneath.
    Regular Member golfdaft's Avatar
    Scotland
    I would just take it back to the garage, I'm sure they will sort out...
    Standing in front of the car bonnet open look down on the inside right of the front lower grill you should find it HTH ....
    Surrey
    Thought it was done there, easy enough to plug it back in rather than take it back. I am sure he just wanted to know where it is.
    Hertfordshire
    It's the facelift model guys so when I open the bonnet there is no gap between back of grille and radiator. ie. No access?
  1. Vac gauge
    By paulvectrac in forum Petrol Engine related
    Last Post: 27th October 2012, 20:13
  2. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  3. temp gauge
    By ptrehearn152 in forum Electrical & ICE (including SatNav)
    Last Post: 5th February 2009, 21:29
  4. Replies: 2
    Last Post: 15th September 2008, 23:18
  5. 0 gauge
    By kevster in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2008, 23:07
