Results 1 to 10 of 16
Thread: Adding acetone to fuel?
    South Central England
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Default Adding acetone to fuel?
    Just been reading on VVOC about adding acetone to fuel to reduce surface tension and create better emulsification in the cylinder, thus producing a better burn and more power/efficiency...
    I'm up for trying most things but I'm not sure I want to jump in with this one.
    I've done it on a few occasions matey. If definately pulls harder, but I wouldn't recommend it long term.
    Best to buy a good quality diesel instead.
    Regular Member Geoshaw's Avatar
    Armadale (West Lothian)
    How much would you add to a full tank?
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    They recon about 50ml per tank of fuel
    Where can I buy some and what damage is it likely to do?
    spoons
    Guest
    Just take out the spare wheel..... you'll get a bigger performance difference and save money.... until you get a puncture....
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Quote Originally Posted by Geoshaw
    Most chemists sell it -it's used for nailvarnish removing!
    It's a very powerful grease solvent, so I guess that it may reduce the effectiveness of the lubrication in the bores.
    Phil
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    If used regually, I would imagine it would degrade seals and increase wear, both in the fuel pump and the engine.
    I added 60ml to every 40 litres of fuel. But only use it (if you really have to) once in a blue moon IMO.
    Probably get shot here, only my opinion, but here goes ...
    Do you guys think you have bought the right car ? If you are going to this extreme I would suggest a vectra wasn`t the ideal choice in the first place ??
  1. Adding Aux
    By Ginge7289 in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2011, 10:52
  2. Adding a manual Fuel Pressure regulator?
    By Caveman_nige in forum Petrol Engine related
    Last Post: 7th March 2011, 14:01
  3. Adding DAB
    By Blue Thunder in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2008, 21:57
  4. Acetone in fuel/your views?
    By glencol in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2008, 17:39
  5. Adding Sub and Amp
    By Adamant in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2006, 00:34
z19dth acetone
