Thread: Standard CD Player - code entering?
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    Default Standard CD Player - code entering?
    I have put my original CD Player back in the vectram, i have the code but i dont know how to enter the code. Is there a certain button i have to press and then enter the numbers?
    Sunny Dartmoor
    Switch ignition off,press and hold the AS button and then enter code using 1234 buttons and then press and hold AS button untill you hear a beep,hth Gregg.........
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    actualy you switch ignition on,with the radio off press in and hold the AS button,switch the radio on (with as button still in) the display should change to 10 ---- let go of as button,using buttons 1,2,3,4 you input the code,keep pressing button 1 till the first digit shows,button2,3,4 you do the same so the code you have is shown on the display,you then now press and hold the AS button again,hopefully the radio should start working
    Regular Member darko2301's Avatar
    Croatia
    exactly
    you have to switch ignition on, turn off the radio and the turn it back on while holding AS until you hear the beep..
    hold AS again a few seconds to confirm the code..
    Aug 2007
    Great Wyrley
    Ok cheers guys, hopefully have someone buying it tmrw and dont want to sell it without that working really.
  1. Standard CD player
    By winty234 in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2010, 13:01
  2. trouble re-entering security code (ccr 2006)
    By bobssignum in forum Electrical & ICE (including SatNav)
    Last Post: 29th October 2008, 22:07
  3. SatNav on a standard in car dvd player
    By jaxouk in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2008, 20:27
  4. Entering Code on 2006
    By spacenase in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2006, 14:52
