Thread: more expense on my car
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    Angry more expense on my car
    after having to pay £49 to nationwide autocentre for a diognostic charge on the knocking on my car and they also said inner cv joint,well the joint was making a knocking noise but not the main loud knocking,this is still going on,i had a search and i can hear it,i can feel it but i cannot find where it is coming from,what i did find was the right side coil spring is broke,it was not obvious in visual inspection as the plastic sleeve was holding the lower part of the spring in place,the knocking noise seems to be coming from the passenger side and evn my father has heard it coming from the passenger side,i have stripped the passenger suspension down and i have found nothing wrong,the noise can be replicated by rocking the steering,by pulling off and while driving the car backwards and then applying the brakes,i have already paid out over £200 on parts (lucky i get a good discount) now i have to pay out nearly £200 on more parts with no guarantees of fixing the car,i have not yet checked the front part of the subframe but the rear part of the subframe,rack and arms are all tight and i have checked for movement with a large screwdriver or crowbar and have found nothing wrong,the knocking is getting worse but nothing is obvious
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    this knocking i have which is coming to the left/central of the car,could the DMF do this? it only does this when pulling off,i know i have a broken spring which is causing some noise but the spring that is broken is on the right side and there are no noises coming from that side of the car,this knocking is now getting annoying and so dar i have found nothing wrong that could cause it.please help as i dont know where else to look
    the knocking can be heard in this video,more so mid way,my phone was on my passenger front footwell
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    anyone???????
    before i do something i shouldnt,this car is getting on my nearves
    Regular Member bertbuckie1's Avatar
    Turriff - Aberdeenshire
    lmfao thats the worse video ever....have you checked your driveshaft bushings ? try grabbing the wheel when your cars parked and moving it back and forward - i had this problem before in my clio
    ...kinda hard to help from the video/soundtrack sorry -- is it as you harshly accelerate or change gear ?
    Kent
    I think he has just put the camera on the passenger seat and driven round, could it be the radiator mounts?
    Regular Member david.aka.judas's Avatar
    Suffolk
    the scary thing to me is the fact you have a broken spring and your still driving it. I would get that fixed and then so to the other....imo.
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    Quote Originally Posted by bertbuckie1 View Post
    never when changing gear
    Quote Originally Posted by Judas View Post
    i only found out on friday,and it is only about 3 inches at the bottom,the ride hieght has not dropped,if you look nothing looks amiss
    Quote Originally Posted by fattony View Post
    i only played a video as mobile phone recordings are not easy to convert for use on the internet where video is easy,the phone was on the footwell
    i will have another look,i dont think it is the rad mounts as the noise is coming from the steering rack/rear of engine bay area,i just cannot pinpoint it which is annoying
  1. Today's expense
    By mattspear in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2012, 13:22
  2. Have a laugh at Manchesters expense...........
    By merikiito in forum Comedy & Humour
    Last Post: 8th December 2011, 13:47
  3. A non Vectra expense
    By silverhairedracer in forum General Chat
    Last Post: 3rd August 2009, 07:17
  4. Egr valve - expense?
    By MRLUBBERLUBBER in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2008, 10:33
  5. More Expense
    By phil67 in forum The 'Off Topic' room
    Last Post: 26th August 2008, 12:34
