Thread: New griffin logo
    Regular Member Dippy-Vx-line Red's Avatar
    Earlston (Scottish Borders)
    Default New griffin logo
    Does anyone know where i can get one of the above for my facelift V-grill.....
    Regular Member Steven T Davies-Moss's Avatar
    shropshire
    Quote Originally Posted by dippy27 View Post
    Ditto.. i was gonna try this too
    Full Member gibbon7000's Avatar
    lincs
    The dealers
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Quote Originally Posted by gibbon7000 View Post
    The dealers
    they sell all sorts of stuff ......................
    merseyside
    maybe you could try ebay as i was looking for the same
    Regular Member Bethan39's Avatar
    South Wales
    Quote Originally Posted by Maverick View Post
    Right then, not so much as a how to as it is a very easy job to do.
    Rear tailgate badge - Part Number 13266396 Retails at £18.40 + VAT
    This is pretty much identical in size to the Vectra C and Signum tailgate badge. You will need to remove all the clips from the back, add some double sided trim tape and stick on your tailgate.
    Wheel Centres - Part Number 13242423 Retails at £2.57 + VAT each + VAT
    Based on the original Vauxhall 18" and 19" Wheel centres, prize out the original badge and the dark grey disc from the wheel centre cap.
    Using the Insignia wheel centre, cut off the clips off the back of the new centre and remove the locating ring, basically to ensure that the back of the new wheel centre is flat and no clips showing. Get hold of some of the black sicoflex glue, add a dollop on the original wheel centre and fit the new wheel centre on the top, but make sure it's central! Leave to dry and then fit back on your wheel.
    Regarding Vauxhall's 17" wheels that have just a small round wheel centre, the new Insignia may just clip into place but I have not tried this.
    Steering wheel - Part Number 13242423 Retails at £2.57 + VAT
    There are two ways of doing this, reversable and non reversable. Firstly you need to emove the chrome griffin from the new Insignia wheel centre. Then remove the lugs and clips to ensure it is flat.
    Option 1 Reversable - Get some black vinyl and cut out a disc the same size as the new badge. The new badge is the same diameter as the giffin on your airbag. Stick the vinyl disc on your original griffin and using a hair dryer ensure it is well stuck down. Then using trim tape stick on the new badge. With this method you can't tell the old griffin is still there unless you look very very closely and the edge of the new badge fits snugg to the airbag.
    You can then remove should you wish at a later date.
    Option 2 Non reversable - Remove you airbag, and using a dremmel, slowly grind back the original griffin until it has been gradually rubbed away leaving just a flatish disc. Locate some seperate black plastic sheet and make a new disc for the new griffin to sit on. Once this has been fitted use sicoflex and glue the new complete badge to the airbag.
    I have done both, the second option on an old deployed air bag and to be honest with the extra work involved, it does'nt look much different to the reversable option.
    Front grill - Insignia front grill badge required Part No TBA £140 + VAT
    Firstly you need the Opel chrome grill panel, or OPC primered version to replace your V grill. This will fit perfectly once the V has been removed.
    The reason the Insignia badge is so expensive is because you have to buy it with the complete grill. So remove the badge from the grill and fit to your Opel grill, which is within 2mm of the Insignia badge. Job Done
    Front grill keeping your V Part Number 13266396 Retails at £18.40 + VAT
    Remove the original griffin, make a new black disc to mount the new badge and then fit to the front in place of the original, it is slightly bigger than the original but looks OK. I am sure Shan has done his this way.
    Hope this helps!
    Here you go HTH
    Was looking at these on ebay..but are they not just a little big?
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...Category=72211
    Regular Member Baz07's Avatar
    Lancashire
    Guys the one from the ebay link is 95mm, and is the one that both myself, Shan and others have used.
    Full Member spennny's Avatar
    Blantyre
    Quote Originally Posted by Baz07 View Post
    Correct.......and a pure cant to fit
    so how did ya fit it then???
  1. Replies: 2
    Last Post: 21st August 2011, 11:38
  2. Replies: 8
    Last Post: 9th May 2011, 22:08
  3. Logo help please..
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2010, 19:13
  4. griffin logo
    By payney in forum Bodywork & Interior
    Last Post: 27th September 2005, 20:33
