Results 1 to 10 of 19
Thread: 30cdti engine noise
    Regular Member 30ltr nutter's Avatar
    dunstable
    Default 30cdti engine noise
    hi guys i have a 30cdti when stationery and u rev the engine the engine has a harsh noise coming from the engine some wear no power loss and no warning lights the car was ok sent it for mot and came back with the noise never noticed it before mot . any suggestions mant thanks
    What mileage is the car on?
    Whats the service history like?
    What oil has been used?
    Bristol
    It may be the egr oscillating. Or may be the dual mass flywheel starting to give up .
    dunstable
    its done 43.000 full vx service history and wat ever it neads it gets it also gets oil changed every 10.000 even though it does not nead it it sounds like it is over boosting but no warnings or stored errors it seems to muck about at lower speeds if ur above the speed limit on a private road ect its ok but if u sit at 50mph it starts too pull back then engine kicks back then its ok for a couple of miles then it does it again with no warning lights ect ive booked it in to stealers for tuesday to c what they come up with
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Mine's developed a weird diesel clatter when I accelerate from about 1300rpm. It disappeares at about 1600rpm...
    Could it be that the valves need to be readjusted?
    50mph assuming in 6th gear is just below the turbo activation
    Are you able to replicate this at other low rev speeds, such as 40mph in 5th gear, 30mph in 4th gear, and so on
    When you are at these speeds is there any black smoke given off (have someone drive behind if required)?
    dunstable
    it smokes on hard excelloration it does not seam to like slow speeds and the torbo seams to be in at low speeds and there is a turbo whistle if u rev the car stationary but the turbo is working it pulls well it seams to smoke heavy on excellorating not just a puff of smoke its continuos smoke till u stop excellorating
    A small amount of smoke at standstill with hard revs is normal
    However, smoke at revs in normal use is not
    This suggests the EGR pipe on the turbo may be near to failure or already has
    This is also usually joined by a wooshing noise between 2000 and 2500 rpm (it sounds like rushing water)
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Our 2.2DTi Auto does that!!!
    I'm going to check the pipe coming from the EGR tomorrow.
    dunstable
    hi in what way does it fail and is it a metal pipe or plastic or rubber when it fails what does it do or not do meaning does it stop turbo operation or incorrect air flow or fueling faults on reving it sounds like its got a dump valve fitted so does that mean it looses pressure or some thing
  1. Misfire on 30cdti
    By lopku001 in forum Engine & Drivetrain
    Last Post: 30th July 2011, 14:37
  2. help needed vectra 30cdti 2005
    By 30ltr nutter in forum Engine & Drivetrain
    Last Post: 3rd November 2009, 20:48
  3. smoking 30cdti
    Last Post: 18th November 2008, 23:52
  4. 30cdti bhp
    Last Post: 7th June 2008, 14:11
  5. sick veccy 30cdti
    By 30ltr nutter in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2008, 18:44
