Thread: whining noise (HELP)!!!!
    Regular Member wilsons 1.8sxi's Avatar
    manchester
    Default whining noise (HELP)!!!!
    this noise sounds as i have a flat tyre you dont hear it until a get to about 50-60 any clue what it could be other that the tyre or wheel bearing
    Last edited by wilsons 1.8sxi; 19th March 2009 at 20:36. Reason: P.S THE TYRES ARE NEW
    Full Member lizard's Avatar
    Oct 2006
    southampton
    11 Post(s)
    if your on your own it probably is, if your wifes with you then it's probably her whining your going too fast......
    Regular Member keithsimmo's Avatar
    in the engine compartment.
    You edited that the tyres are new? Has this only happened since you had new tyres fitted? Have they put them back on correctley? any lables on the inner side of the tyres causing noise? There is a release compond used on tyres to get them out of the mould not sure if this could be related? Where is the nosie front rear ? left right? Are you sure it's not the other half? You have let them out of the boot right?
    manchester
    i'm gonna give it a good going over tomoz to see what it could be cheers for all the replies i'll check what you've all told me to check and also it sounds like its coming from the front
    WGAF#5
    are the tyres directional ? if so are they on the right way, and what make are they - some of the "budget" tyres are very coarse and will generate more road noise, could also be a wheel bearing beginning to go that you havent heard before
    good luck with sorting it
    regards
  1. Whining noise from Altenator
    By Hammy in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2013, 20:47
  2. whining noise
    By Swedge in forum Engine & Drivetrain
    Last Post: 21st November 2012, 23:23
  3. Whining noise - help needed
    By b17e30 in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2010, 08:22
  4. Whining Noise
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2008, 09:08
  5. Whining Noise
    By v6boy in forum Engine & Drivetrain
    Last Post: 13th May 2007, 01:13
