Thread: Rear engine stabalizer mount
    Apr 2006
    Suffolk
    Default Rear engine stabalizer mount
    Ive been told by my local dealer, Quest Motors in Braintree, that when you release the clutch pedal and put your foot on the accelorator on all vectra c's you will get what I can only describe as the engine rocking backwards and forwards. It feels like one of the engine mounts is loose and worn but ive had both front and rear stabalizer mounts replaced under warranty but it still does it. Is this true, and if not, what could it be?
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    mine has a slight knock sometimes i've had a look and theres no play/movement in the mounts so have got used to it
    Apr 2006
    Kent
    Mine does this however today it seems really bad? Anyone else have this problem where it has got worse?
    If so what do I do? My car is still under warrantee or however you spell it.
    thanks.
    the mounts are under the 3 year plan, so just take it back and get them changed.
    all engines move to a degree, they have to, it's a natural reaction to the torque they are producing..anyone that's seen a car rolling roaded will testify that the engine moves quite a lot when it's under power..
    should it knock..not really, but getting VX to find it may be a bit hard as all they do is prybar the mounts to see if they're worn out.try getting them to testdrive the car..
    Apr 2006
    Kent
    Thanks for the info I'll get it booked in ASAP.
    thanks.
    Berkshire
    Mine does this from time to time, i was wondering what the noise was!!
  1. Rear Engine mount
    By Big_Rich in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2011, 15:58
  2. Help with getting engine mount off/cam belt
    By Mads in forum Engine & Drivetrain
    Last Post: 9th March 2011, 22:14
  3. z18xer o/s engine mount? what is it the same as?
    By vxr in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2009, 23:47
  4. Engine mount query?
    By dh.dti in forum Engine & Drivetrain
    Last Post: 17th June 2008, 13:10
