Results 1 to 10 of 16
Thread: 2.2 oil leak
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Default 2.2 oil leak
    Can anyone tell me what this is. Its spitting oil over my Z22SE. Its on the bottom of the head/top of block. This pic is taken looking from the firewall on the left side of the engine.
    The big silve thing is the manifold heatshield.
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Not a clue, what is it?
    Nicking Ya Dinner.
    Not knowing what a Z22 etc engine is, I'm guessing its a petrol one?, it looks like petrol or water to me from the photo, but whatever it is it doesn't look serious enough to weorry about just yet mate, is it on the inlet manifold? if so, i've seen many like it, you gotta stop gunning the **** out of it, it's a car not a F1 barge.
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Exhaust manifold?
    Can't see where that is leaking from. Looks like the manifold, but if it is, it is a leaky valve seal or something....
    Can't see very well though.
    South East
    Strange that they've changed the flow from front to rear as per 205/309 GTi (car gets more French as I pull bits apart) and tilted back as per French. This does allow easy access to sump work etc. I do not want to be drilling the studs out the Ex. manifold on this one.
    If you oil is clean then this is the kind of mess/colour it would make. If you have a small leak sometimes the wind and vibration can move it about making leak location hard (remember a small amout of oil can go along way). Can't think why the stud would have oil on it.
    Will have some thinking on this one.
    Feb 2006
    Guttedsville
    If it's under warranty still, get it back into VX. I'm not saying there's something wrong, but that's what warranty is there for.
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    if its leaking from the manifold suspect valve stem seals (warranty job!!)
    South East
    Quote Originally Posted by Beavis
    Sounds a possibility as the oil will blow out on startup and some might drip but would expect blowing noise from manifold gasket.
    Looking @ the pic on an LCD screen it does look like oil.
    Are you one of the smoking on startup people, how many miles on the clock.
    Keep everyone informed how you get on as loads of us have these units in our motors.
    Nicking Ya Dinner.
    Having had a sober look mate, I think it could be as Bevis and CDTi say.
    Vehicle : SRi
    Mileage : 137000
    went to vx, they said it was a leak from rocker gasket. 53 plate and only done 22000 miles so fully covered. will let you know if it is anything else when it goes in for a proper look.
  1. Oil leak 150 cdti oil leak help
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:46
  2. Oil Leak
    By Tam80 in forum Engine & Drivetrain
    Last Post: 17th January 2011, 13:41
  3. Oil leak
    By Rich2.2 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2010, 20:31
  4. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
  5. 3.2 oil leak from?
    By megaderek in forum Engine & Drivetrain
    Last Post: 29th September 2009, 22:45
gearbox oil leak on vectra c 2.2 sri
vectra c petrol leak
z22se oil leak block and gearbox
oil leak vectra
common oil leak vectra 2003 2.2 petrol
vectra 2.2 oil leak
vectra 2.2 oil leak sri
vectra c oil leak on front of engine
vectra b 2.2 16v engine oil leak
vectra c 2.2 oil leak
