Thread: Get you home code
    Kingston Upon Hull
    Question Get you home code
    If a ecu goes into get you home mode [ safety mode ]
    how do you clear it tec2 ? and what code number would it be
    we are getting no signs it is this but the engine will not rev above 2500
    its a diesel 2l in a 04 reg vectra c
    Thanks for any help
    Jacko
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by jacko52 View Post
    Thanks for any help
    Jacko
    Disconnect the battery over night for example and the ECU should re-learn itself.
    Northampton, UK
    Does it not reset after you turn the ignition off? If its still in limp mode, you'll need to get the fault code read and reset at VX
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    looks like its a trip to the stealers
    Regular Member keithsimmo's Avatar
    in the engine compartment.
    Default EGR Valve again?
    Sounds similar to my symptoms, not reving over 2000-2500.
    I did have fault codes but was resolved by cleaning out the EGR valve both sides.
    Here are some useful links that might help you..
    http://www.vectra-c.com/forum/showthread.php?t=39441
    And cleaning the solenoid side of the EGR valve
    http://www.vectra-c.com/forum/showthread.php?t=45867
    And a handy little printable PDF too!
    http://www.vectra-c.com/forum/attach...7&d=1232829228
    Thanks to "Jon7278" for putting the How 2 together and
    "cdti 150 SRi54 est" for the PDF.
  1. egr blanked - 2000 miles and no limp home home
    By jonestown in forum Y & Z30DT Specific
    Last Post: 1st August 2012, 14:55
  2. Car Pass - Result! Key Code & Radio Code
    By mxt in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 13:01
  3. Replies: 71
    Last Post: 30th April 2008, 12:38
  4. ah! home sweet home!
    By pogo in forum General Chat
    Last Post: 20th October 2007, 21:03
  5. home sweet home aarrrrggg i love it !!!!
    By big phil in forum Introduce yourself.
    Last Post: 9th June 2005, 08:04
