Thread: Vectra Visor Clips
    Regular Member nick-v2.2's Avatar
    Nottingham
    Default Vectra Visor Clips
    Recently had to remove my head lining, and in turn remove pretty much everything else.
    One thing i have not managed to get back on properly is the sun visors.
    Is there a trick to getting these clips back on. Its the one where the pin slides through the middle and into a indentation on the inside of the clip.
    So far I have managed to snap both of the pins.
    Is it easy enough to get hold of the pins. Or the clip as a whole if necessary. and is it actually possible to fit them again?
    Nick
    Sunny Dartmoor
    You need to remove the metal part in the roof and then assemble the clip,then just push the complete clip into the roof,can you tell i had the same problem,hth.......
    Nottingham
    how does the metal bit come out tho lol? i tried forcing it out with a screwdriver once already :P
    Sunny Dartmoor
    It fixes in both sides,just use a pair of pliers and squeeze it together should just drop out..........
    Nottingham
    Ahh Thank you very much. Your a star. If only i was clever enough to check that and remove them before putting the head lining back in lol.
    My pliers didnt quite do the trick. Used a screw driver both sides. Ended up pushing the first one in instead of pulling it out.
    Then using a bendy screwdriver bit pushing the metal clips toward the front centre. So i could put my hand round up the front of the headlining and grab them. Aswell as tear my hands to pieces.
    Since your first post there now down
    No more worrying about the visor dropping down in front of me
    Many Thanks
    Full Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    you are not the first to make that one i had the same problem...
  1. Sun visor clips
    By Jamston39 in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2013, 19:29
  2. Re-attaching Sun Visor Clips
    By Neve'o in forum Bodywork & Interior
    Last Post: 22nd August 2012, 07:42
  3. Sun visor retaining clips
    By stevie16v in forum Bodywork & Interior
    Last Post: 27th September 2011, 19:04
  4. Sun visor bulbs in Vectra C
    By Mark Curran in forum Engine & Drivetrain
    Last Post: 18th July 2011, 23:20
  5. Vectra passenger sun visor retaining clip problem
    By Ollie in forum Bodywork & Interior
    Last Post: 19th January 2010, 16:29
