Thread: cracking noise?
    durham
    Trim : Leather
    Default cracking noise?
    hi guys, does anyone know why i get a loud cracking noise from my drivers side door, it is comming from the door check metal plate that goes inside the door, this happens everytime its opened and closed, the cars only done 39k. any help is appreciated.
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    driving too close to the hedges?
    mine made noises but gave all the moving bits a squirt with lube
    durham
    Trim : Leather
    done the usual, looked for loose nuts, squert of wd, no joy. its from inside the door and like i said its a loud crack.
    durham
    Trim : Leather
    anyone help?
    Surrey
    I would use grease rather than WD40. Coat check strap and hinges in grease and work it in to see if that solves the problem. If not it's the check strap.
    WGAF#5
    replacement check strap about £15 quid did mine last month
    door card off and speaker out undo the bolts slip out of the speaker gap -replace refit speaker and door card - done in about 30 minutes
    no more noise
    there is a how to on replacing speakers which shows how 2 dismantle the door card and where screws etc are - if you need any help give me a shout
    regards
    Dez
    durham
    Trim : Leather
    steve and deztroyer many thanks for your help i will try the grease first and if that does not work then its a new check! cheers guys.
    New Member Bob Acid's Avatar
    Herne Bay
    I've got this problem. Tried greasing so it's a replacement strap. Thanks lads.
  1. loud cracking noise when opening/closing door
    By marky2027 in forum Bodywork & Interior
    Last Post: 5th December 2011, 20:19
  2. Rear creaking/cracking noise
    By andythilo in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2010, 23:46
  3. I'm cracking up
    By bigbnlr in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2009, 19:27
  4. Replies: 0
    Last Post: 25th June 2005, 16:11
  5. FR 1516: C-Pillar - Cracking Noise (Vec C)
    By Duncan in forum Body & Body Equipment
    Last Post: 25th June 2005, 15:35
