Results 1 to 3 of 3
Thread: Problem with Vec!
    Regular Member andythilo's Avatar
    Oct 2006
    Saffron Walden
    Default Problem with Vec!
    Well it's going very soon but has developed a problem. Basically it's going into limp mode and the engine warning light is on. It's fine normally for 5 mins or so after starting but then I lose loads of power. No juddering etc..l just loss of power.
    Took it to the stealers and they quoted £600 for a new intake manifold and said it's a swirl flap malfunction.
    Now reading on here it sounds like the loss of power is the EGR valve, can anyone shed any light on this?
    I've read about the swirl flap fix on here using the washers so I will have look under the bonnet tomorrow.
    Merseyside
    I had the swirl problem on mine and no warning lights came on at all. By the sound of that, the EGR is possibly clogged up with cack. Whip it off and clean it out and I'm sure you will notice the difference!
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    The swirls can give EML errors. Have a nosey under the bonnet and check the swirl connecting rod to see if its still attached or if its fallen off.
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
