Results 1 to 10 of 20
Thread: Tested out some new kit
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default Tested out some new kit
    Call it either Equipment Familiarisation or 'playing'.
    Anyway, I connected a current monitor to the starting and charging cable to the battery and did some tests. Data logging and then charting the inpact on current flow gave these interesting plots.
    +ve current is discharging the battery
    Starting the engine (got the axis labels the wrong way round here - oops)
    Notice how the current for each compression reduces and so does the duration, as the engine is increasing in speed and each firing is providing rotational forces on the engine too.
    And then the charging part, with various electrical devices working
    Enjoy............ almost as much as I did.
    Edinburgh
    interesting, think you might need to get out more though :P
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I'm at work, and it got me out in the fresh air for a bit......
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Interesting....
    Not sure about the scaling on the charging current, surely it doesn't take 100A to run all the kit?
    Phil
    Regular Member AntB's Avatar
    Trim : GSi
    Mileage : 39k
    Can you do another one with the power steering? I swear mine draws so much power that not only the car lights dim, but so do the street lights within a 50m radius of the car.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The kit was laptop powered, the initial charging rate was just for battery charging, shortly after start, then it also powers the auxiliary current draws for lights, demist and blower.
    Quote Originally Posted by Ste View Post
    The kit was laptop powered,..
    I think he was meaning the kit in the car i.e. he didn't think that there would be a pull of 100A for running the car and the accessories (lights , demister etc.) that were on.
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Quote Originally Posted by AntB View Post
    I was just about to say the same, but its the voltage that drops in that case to cause the lights to flicker. The voltage regulator quickly irons out the spike though. I think an initial tug on the steering drops the voltage by 2 volts, although its very quick to compensate on the test mode display on full canbus Vecs.
    PS:Sorry about poor grammar my apostrophe is printing a # at the moment!
    Regular Member scottyd's Avatar
    paisley
    Quote Originally Posted by John C S View Post
    its bactualy current draw(amps) which cause the lights to dim
    May 2007
    Quote Originally Posted by scottyd View Post
    Top man, thanks for the correction.
    I'm not worthy.
    PS Bactualy? Is that an actually back in time ( a past tense )
    Over to Ste, for the rest of the experiment........
  1. Astra VXR: Tested
    By VectraV6CDTi in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2007, 10:44
  2. When Top Gear tested the VXR
    Last Post: 26th November 2007, 08:10
  3. Tested a VXR
    Last Post: 28th October 2007, 23:24
  4. CDTi 1.9 150 SRi: Tested
    Last Post: 29th July 2006, 10:47
  5. tested
    By cyb in forum Signature & Avatar Testing
    Last Post: 9th April 2006, 16:54
