Results 1 to 10 of 25
Thread: Tech2 to adjust speedo??
    Cambridgeshire
    confused Tech2 to adjust speedo??
    As the title says is this possible? I've recently fitted my snowflakes and i want to make sure that i'm not going faster than i should be. Can i just take it to Vauxhall?
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    interested in this thread
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    If you've put the correct tyres 235/35/19 on then there's no need.
    birmingham
    Engine : 3200
    Quote Originally Posted by MalcGSI View Post
    i have,
    my sat nav is stating 4mph faster than the cars clock?....im posative it never use to be like that before the flakes were fitted
    Mileage : 000
    I would have thought you can. Perhaps Duncan will be able to answer the question as he has a form of "tech 2".
    birmingham
    Engine : 3200
    Quote Originally Posted by ed taylor View Post
    cheers ed
    [Ex]Admin Duncan's Avatar
    You'll have probably gained a little bit of extra 'error' by changing the wheels, but probably not enough to be worried about - it'll just be maybe reading another 1mph over from what it was.
    In reply to your question - yes, you can get the setting changed in Tech 2 but is it worth paying for a Tech 2 session for that?
    Equally, Vaux-COM can do it so if you were ever at a meet at the same time as me I'd adjust it for you no probs.
    Rich - your speedo would have always overread by at least a couple of mph even with your standard wheels on. The larger wheels will have simply increased that error slightly more.
    EDIT: And here I am! lol
    birmingham
    Engine : 3200
    i panic at speed cameras now so if its a 30mph i do 25mph and if its 40mph i do around 35mph, im going to have to get it done as its really bugging me
    Cambridgeshire
    That sounds alright, i'll probably just leave it then. Can you also activate (if it needs it) my TC switch using your form of tech2?
    Regular Member LJ sxi-nav's Avatar
    Winchester
    Quote Originally Posted by big rich View Post
    Wouldn't sat-nav normally UNDER read the indicated speed? I.e. the car's speedo will be over reading the actual speed reported by SAT-nav?
    So at an indicated 60mph, sat-nav might say 58mph. It would be an MOT failure if it was the other way around surely?
  1. Handbrake? is it self adjust?
    By dave1419 in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2013, 12:31
  2. headlight adjust
    By vectraross in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2012, 15:01
  3. how do i adjust my headlights??
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2010, 16:41
  4. Help please, how to adjust the headlights
    By PeterVV in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2010, 21:10
  5. Clock adjust
    By johnny1983 in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2009, 18:12
