Thread: 2.2 Cam Chain when should it be changed?
    South East
    Default 2.2 Cam Chain when should it be changed?
    Anyone know the mileage for when the cam chain should be changed.
    I've the modified one (all black rocker cover) but not sure when it should or should have been changed.
    Don't want it snapping
    iirc it doesn't need replacing - it's a 'life of the engine' part. That's what I was told about the cam chain in my 2.0T - so I'd imagine it's the same in the 2.2. A phone call to the dealer to confirm wouldn't do any harm though!
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Wasn't aware the chain type needed changing. I enquired for my 2.2 dti which is chain driven and was informed it doesn't need replacing. Only time these chains can snap is when poor quality oil is used or service intervals are to long for the mileage. The nozzle that lubricates the chain becomes blocked thus drying the chain out and snappage!!
    South East
    Annoying as the dealer was asked whether it needed changing on the last service but they failed to comment.
    Nicking Ya Dinner.
    It doesn't need changing, but hey! it's up to the owner really, if you want peace of mind change it anyway, also to put your mind at rest, if there is a problem on the horizon you will hear it, so if it becomes rattly or you are getting other noises from that area act now not later.
    Regular Member Jatie's Avatar
    Heathrow
    Vehicle : Vec B sri150 & GTi 150
    Trim : SRi150
    Engine : Z22SE
    Year : 2001
    Mileage : 49k
    Vx say the chain is good for 100k & over .
    Change the oil & filter every 6k or 6 months & you will be fine .
    I was aware there is an issue of cam chain failure on the Vec B because of the oil jet nozzle getting blocked because of the prolonged service intervals & also the circumference of the nozzle being smaller .
    But I was told the Vec C had the modified oil jet nozzle fitted from factory .
    Regular Member Doug-SRidirect's Avatar
    Hemel Hempstead
    Should last the life of the rest of the engine, provided it's been maintained correctly.
    Doug
  1. Changed my car
    By wolvesdaz in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2012, 19:48
  2. CIM CHANGED NEED TECH2 in OXFORD AREA HAS ANYONE CHANGED A CIM BEFORE?
    By vectrasimonsri in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2011, 20:43
  3. How do you know if Chain has been changed
    By daytona in forum Engine & Drivetrain
    Last Post: 10th April 2010, 15:42
  4. a little bit changed
    By andyman201 in forum Signature & Avatar Testing
    Last Post: 28th March 2010, 14:37
  5. My Name Has Changed
    By 3.2_V6_VXR in forum General Chat
    Last Post: 18th July 2007, 04:37
