Thread: MOT fail due to brake pedal creep
    Regular Member baztheman's Avatar
    washington tyne & wear
    Angry MOT fail due to brake pedal creep
    Hi all well its been a labour of love this week.....
    getting the car ready for its 1st mot since i owned it has took its toll on me.
    x2 rear boomerangs
    x2 front springs (both were snapped)
    x2 track rod ends
    x1 track rod
    gm oil change (nearly £80) robbing gits
    x2 new tyres (goodyear nct5)
    and it ****** failed the mot eeeeekkkkk
    well the tester said it had failed on 3.3.b.1a (brake pedal creeps down when held under pressure)
    well im off to the local vaux steelers and would like a 2nd opinion as i have read on here and other places that its a symptom called diesel creep.
    with engine switched off and pedel pumped it goes rock hard and does not sink,when engine is started and pedal pumped it will sink down.
    i done a brake test and it stops spot on and abs kicks in on emergency brake test!
    so i now need to speak to a vaux tech for advice (i may have the brake fluid changed even though others have done the same and it didnt make any difference)
    i will keep you all informed..... i even missed the ne rolling road day due to the major front end repairs (sorry chunk m8)
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    Pedal creep on these IS normal, and can catch people out who dont know about it.
    yea plasma m8 i know but it shouldnt catch out a mot station... hmmm
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    it just goes to show that standards are not even across the board
    the pedal creep is normal
    the first time i noticed it on my vec i thought i had a problem and booked it into vx straight away
    when told this was normal i raised my concerns about this failing an mot and was told under no circumstances would my car fail an mot with this
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    A fluid change will make no difference. It is inherent in diesels due to how the brake servo pressure depression is created (via a vacuum pump) and is normal.
    Interesting link http://www.motuk.co.uk/manual_330.htm
    Cambridgeshire
    That's an interesting read. Perhaps with some MOT stations you will have to tell them (because some may be morons) that you have a servo assisted hydraulic system.
    Update!
    well been to the stealers and they confirmed that it is known to them but they wernt to helpful.
    went to another mot center and they said the same "he should have passed it " he said
    so on the way home i called to the mot center and i spoke to the tester,he had just had another veccy in and it showed the same thing he said and said he was going to phone me .
    so a new pass certificate has been made out ..... job done
    ime sure there is a lesson to be learnt here ..... but i dont know what!
    cheers...baz
    Regular Member LJ sxi-nav's Avatar
    Winchester
    good result there. What a numpty tester!
    Chelmsford
    Is it only on diesels that this is normal?
    It happens on my car too and its a petrol engine... It worried me at first until someone said they all did it.
    Quote Originally Posted by baztheman View Post
    Update!
    cheers...baz
    Glad to hear that's sorted for you m8 ....
  2. For Sale: Vauxhall Insignia Brake Pedal Alloy Cover - SRI sports pedal cover
    Last Post: 20th December 2012, 21:36
  3. brake peddle creep
    By Al 22 dti in forum Suspension, Wheels & Brakes
    Last Post: 3rd October 2012, 22:27
  4. Brake pedal creep - 2.0T - MOT failure!
    By Gus93 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th June 2012, 20:40
  5. Brake pedal creep Signum 2.0T (not diesel)
    By olajon in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2010, 12:13
