Thread: abs sensor
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    Default abs sensor
    i had a little accident while changing the inner cv joint,i stretched the wiring from the plug into the hub,can i cut and replace the wire that are damaged or would this cause any other problems,there is nothing wrong with the abs sensor or the hub itself,yes i would be soldering and recovering with heat shrink
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I wouldn't have thought it would introduce any issues, as long as the joints were robust and protected against water ingress, like you say.
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    well i was lucky in i managed to find enough of a wire to solder some wires together after cutting a bit off the end of the plug housing,i resoldered the wires,double heat shrink and plenty of insulation tape,drove the car this evening and the abs/tc lights now go out when they are supposed to,so no trip to the dealer to have the system reset,both wires had broken,i have to remember in future to unplug the abs sensor! lol
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Result then !
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
