Thread: 1.9cdti (150) timing belt change 210 is this ok?
    Regular Member kirkyoke's Avatar
    South Yorkshire UK
    StatsVehicle Info
    Default 1.9cdti (150) timing belt change 210 is this ok?
    hi again all, i have been quoted 210 for my timing belt changing (full kit) by a local indy ... is this reasonable? please could you advise, thank you
    Regular Member RobW's Avatar
    Tain - Easter Ross
    StatsVehicle Info
    Seems quite good to me.
    Does the water pump need doing at the same time? When should it be changed?
    South Yorkshire UK
    StatsVehicle Info
    handbook states 100,000 i'm on 92000 now ... no mention of water pump he just said the full timing belt / pulley kit, cheers
    Regular Member benny's Avatar
    Feb 2006
    dudley
    StatsVehicle Info
    is that a vx kit ? ....or none gen > ?
    South Yorkshire UK
    StatsVehicle Info
    hi benny .... it's a gates kit, he reckons the kit alone is 95, cheers.
  1. Gsi timing belt change
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 1st February 2012, 13:30
  2. 72k on 1.9cdti 150...should I get timing belt done?
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2011, 15:14
  3. when to change the timing belt
    By pmitchell in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2011, 12:42
  4. 1.9CDTi Broken Timing Belt at 69k Miles!!!
    By Vectra-sceptic in forum Engine & Drivetrain
    Last Post: 24th September 2010, 15:16
  5. Timing Belt Change...
    By C19_CJB in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2006, 12:16
