Results 1 to 10 of 16
Thread: Help...Combi Boiler
    Regular Member Damian's Avatar
    Market Drayton
    Default Help...Combi Boiler
    Got home tonight and the pressure of my hot water is right down, the cold seems to be runnig okay.
    Had a look at my combi boiler (Valiant) and the pressure gauge is at 1 bar. When we bought the house we were told to keep the pressure gauge between 2 and 3 bar by turning a little tap under the boiler. I made a wooshing noise and the pressure would increase.
    However when I have turned this little tap, there is no wooshing noise and nothing happens.
    I still have heating, and hot water and the boiler appears to function fine, just no hot water pressure
    Any ideas before I call a plumber
    Here, there and every where!
    What is your cold pressure like. The cold pressure activates a pressure switch in the boiler to light it thus you have hot water. If the pressure drops below 1 bar the switch will not operate. The "little tap" is the cold filling loop which should be at 2-3 bar if the cold supply is ok. Check your stopcock is fully open.
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    PM sent
    Market Drayton
    Cold pressure appears fine, and I am getting hot water through, just no where near as powerful as this morning before work
    This is the filling loop, which when I turn it nothing comes through at all
    and this is the front of the boiler
    Regular Member The Doc's Avatar
    'Norf Yorks.
    You should be cold full around 1-1.2 bar.
    When running it should go upto around 1.5 to 1.8 bar.
    The safety valve blows over 3 bar in the system to stop the pressure increasing.
    Sounds to be like most things are fine but the pump inside the boiler is playing up.
    How old is the boiler?
    Market Drayton
    The boiler is 5 years old.
    I took the hose off at the return valve, and turned the black tap and stacks of water came gushing out. The return valve was squirting a bit of water back at me whilst the hose was off.
    Talking to Ian_C, he thinks the return valve could be blocked
    'Norf Yorks.
    Quite possibly.
    I ain't no plumber mate at all, but have a good idea how the Baxi range work. Corgi registered in the industry but the gas lines I worked on were about 12 inch not 1 inch!
    Ian_C sounds like your man
    Full Member chunkster's Avatar
    North east HQ
    the pressure in the system would have no bearing on the pressure of the water coming out of the hot taps as the cold water basically passes through a plate heat exchanger (heated by the central heating water) and then back out to your taps,
    if the pressure of the incoming cold supply is low then that could be the problem or a blocked filter on the cold inlet pipe. it is possible that the plate exchanger is starting to block
    p.s the filling loop only fills the heating circuit not the hot water side and when you disconnect the hose from the non-return valve you shouldnt get any spraying water!!
    Wayne -
    Regular Member 2ltrT's Avatar
    North-East (Middlesbrough)
    do you work for your self chunkster?
    North east HQ
    no mick i work for redcar p+h, just started on monday
    Wayne -
  1. combi boiler problem ??
    By bembo449 in forum The 'Off Topic' room
    Last Post: 4th February 2012, 10:20
  2. Noisy Boiler
    By crispy007 in forum General Chat
    Last Post: 21st November 2011, 18:52
  3. Combi Boiler!
    By djr69uk in forum General Chat
    Last Post: 5th March 2011, 02:04
  4. combi boiler ?
    By rickeys16v in forum General Chat
    Last Post: 7th September 2010, 22:39
  5. Duff Boiler.....
    By macdad in forum General Chat
    Last Post: 23rd February 2008, 21:38
