Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: Traction control!!
    Leicester
    Default Traction control!!
    Figured out today why my facelift TC button does'nt work.
    And it is a really simple answer. It has not got traction control at all!!!! So this explains the reason, you can't switch off something that is not there in the first place!!!!
    But I have to say, it was only when I broke traction on some grass that I realised. Even in the wet weather it grips very well.
    [Ex]Admin Duncan's Avatar
    You're joking!!! Your facelift SRi hasn't got TC as standard!!?
    <quick pause while he grabs the facelift brochure>......
    Specs say they still have TC as standard, except the 1.8.
    Are you meaning you've bought a TC switch and it hasn't done anything (even though it may have the socket behind)? This has happened to other guys on their pre-facelifts - seems to be a lottery as to whether the TC switch works or not.
    Or have I completely misunderstood?
    Regular Member OilBurner's Avatar
    Feb 2006
    Bromsgrove
    Are you sure Matt? When I turn the ignition on the TC light appears for a couple of seconds.
    When I was stuck in mud it flashed like crazy too!
    I think the real reason the TC button doesn't work is because that switch is set-up for the optional (not even available now?) rear sunblind...
    Jan 2006
    Dalriada
    thats very strange, im with D here i thought all except the 1.8 had TC
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Mine bloomin well does Want mine?!?!
    Leicester
    I have double checked, I have no TC light when the ignition is turned on.
    I will go out in a bit on a peice of grass to check again, but it appears the TC is not even there.
    Leicester
    Nope, just been out, it will spin till it's hearts content if you let it.
    A e-mail to Vauxhall is being written as we speak, I am a little concerned that the 2006 brochure state's in their 'Safety' section standard TC!!
    Dec 2005
    In the sponge-monkey tent
    Thought I read somewhere a while ago that TC gets turned off if you are towing, perhaps having the tow bar fitted did it???
    Quote Originally Posted by Matt
    ....I am a little concerned that the 2006 brochure state's in their 'Safety' section standard TC!!
    That's what I was meaning earlier on. It's still listed as standard on all models except 1.8.
    Leicester
    Quote Originally Posted by Spikey©
    It did'nt on my previous Vectra?
  1. my traction control how to
    By jpbroad1970 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2012, 20:01
  2. traction control
    By ggg1979 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2009, 18:07
  3. 2.0T Traction Control
    By kryton01 in forum Engine & Drivetrain
    Last Post: 20th October 2009, 17:18
  4. traction control
    By jsnlvxr in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 21:56
  5. traction control
    By jamesv6 in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2006, 00:13
