Results 1 to 10 of 24
Thread: just fitted my dump valve anddd
    blackpool
    Default just fitted my dump valve anddd
    it doesnt open .. does this mean its not workin at all ?
    im sure everything is on right
    the only thing that may not be right .. is that the blanking plate i got sent doesnt fit at all .. so i pop riveted the old actuator to work as this same thing ??
    could this be the problem
    Regular Member Preey's Avatar
    May 2008
    Hudd
    could do with any photos you have but it sounds like it should work
    blackpool
    Quote Originally Posted by Preey View Post
    just taken it to the rolling rooad and it isnt boosting at all thats my problem
    Regular Member wiggy's Avatar
    middlesbrough
    Could be the same problem as mine. Have you taken the original one off ??? It may be boosting on the road
    middlesbrough
    Quote Originally Posted by wiggy View Post
    could be the same problem as mine. Have you taken the original one off ??? It may be boosting on the road
    i really should learn to read the threads propperly
    Jan 2006
    Dalriada
    These dump valve's are pressure rated so i doubt it would work with it being pop riveted but im no expert....
    Picture's would help buddy
    blackpool
    Quote Originally Posted by Steven View Post
    well the guy seemed to think it would be okay and it made no differnce having the dump valve on or off
    Regular Member mat100edt's Avatar
    south coast
    Quote Originally Posted by abeckett View Post
    am i correct in thinkin that by actuator you mean the original dump valve as you shouldnt of been any where near turbo actuator and if you have used the original dump valve housing this will never work as you are now permantly rooting incoming air round in circles
    i will try and draw some thing...
    south coast
    if you have removed the insides of standard dump valve then all incoming air will not be boosted by turbo
    blackpool
    Quote Originally Posted by mat100edt View Post
    yeh i did remove that
  1. Bmc cda kit fitted and Bailey Venturi dump valve
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2011, 22:12
  2. dump valve fitted eml on
    By tomo41 in forum Engine & Drivetrain
    Last Post: 5th August 2011, 21:45
  3. who as a dump valve fitted to there veccie turbo z20net
    Last Post: 29th June 2011, 21:35
  4. Sri cdti 120, sounds like i have a dump valve fitted
    By MistyMorning in forum Engine & Drivetrain
    Last Post: 21st January 2011, 23:53
  5. Replies: 23
    Last Post: 6th March 2009, 09:00
