Results 1 to 10 of 25
Thread: Is this normal readings?
    Surrey
    Default Is this normal readings?
    Car failed the MOT on emissions as they said emissions light was on and car was stalling and advised me to leave it there. I argued and got the car back and it drove home and to work fine no lights drives fine.
    I don't think these readings look normal as how can it pass one test they fail next.
    I didn't rip the signature part out, it was given to me like that.
    Attachment 17804
    Regular Member silverhairedracer's Avatar
    ESSEX
    My local garage always suggests to give the car a good blast along the by-pass first so it has a good clear out,when on test also runs test twice if figures are not conforming,
    Hope one of the MOT guys will give you the answer, looks a little contradictory to me ....
    Regular Member Ben999's Avatar
    Milton keynes
    definately something not right there, those figures arent even close to each other! Might as well be a totally different car on the second check.
    Surrey
    No fault codes on car.
    Nearest I could get was on Monday morning at another MOT place so time will tell if they were trying it on.
    Blantyre
    Quote Originally Posted by steve1975l View Post
    If your in farnborough friday mate, i could take the car as its a sit and wait job at my MOT station ?
    Mileage : 000
    Gary/Admin will be able to put this into plain english when he reads it.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The results are bizarre, at the Lambda in the first test, the CO (and HC but less so) is not really possible, and yet despite that with good Lambda (and sensible HC) it fails the second test, I wonder if his foot wasn't steady on the pedal so it was firing transient fuelling through the tests......
    Is it just me, or does the torn off bottom right hand corner also look a bit sus'?
    WGAF#5
    is there normally a date stamp in the bottom corner?
    just adding to the suspicion???
    Regular Member padawun's Avatar
    Sevenoaks, KENT
    On looking at the figures, my guess is that the co has increased on the
    second test as a reult of the amount of fuel/ carbon that has burnt
    on the first test. The hc level is much lower on the second dga print
    which would suggest that the car has a build up of un burnt fauel passing
    through the cat. These readings are not unusual on a town
    driven car, or a car with a lazy lambda sensor.
    Try giving the car a good clear out before repeating the test.
  1. New MOT has last 3 milage readings
    By lee gsi in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2013, 21:33
  2. Can anyone help with these readings?
    By Lozza in forum Engine & Drivetrain
    Last Post: 8th August 2012, 21:52
  3. Need Help with car data readings
    By Mrmac in forum Engine & Drivetrain
    Last Post: 9th April 2012, 23:21
  4. Injector Readings
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2012, 12:23
  5. Inside temperature readings
    By Smove in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2009, 06:27
