Thread: Diesel engine will not rev passed 2500 rpm
    Kingston Upon Hull
    Default Diesel engine will not rev passed 2500 rpm
    Hi a mate of mine has a 2l diesel 04 reg vectra c and it will not rev passed 2500 just when revving it or driving
    he has renewed the egr / air mass valve / renewed the turbo pipes / looked for split vacuum pipes
    we have run out of ideas know
    Can anyone HELP please the car rune's spot on apart from this problem
    Jacko
    Chelmsford
    Sounds like it's stuck in limp mode. Is the engine management light on?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Crankshaft sensor?
    Kingston Upon Hull
    Quote Originally Posted by DNS View Post
    Hi yes the light came on so he had it tec2 and it came up air mass valve so he replaced that and clean the code off
    Kingston Upon Hull
    The light came on tec 2 code =air mass valve so renewed that and cleaned the code off
    Could it be the crank sensor what do others think?
    Jacko
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    That's only a guess...I've no idea what it might be *sigh*
    These old DTi's can be a real pain in the a**e *sigh again*
    Chelmsford
    Only tech2 again will tell... big problem with limp mode is that it means 99% of faults give the same symptoms...
    scotland
    Try driving the car with the MAF unplugged.
    If its better, then the mafs faulty ... i had this problem with my 2.2 DTi
    Regular Member mattolly86's Avatar
    oxfordshire
    which engine is it?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by mattolly86 View Post
    which engine is it?
    2.0DTi Y20DTH
  1. diesel engine re map
    By tyler boy in forum Diesel Engine related
    Last Post: 20th September 2011, 09:34
  2. Diesel Engine Oil
    By John Bishop in forum Vectra C / Signum Troubleshooting
    Last Post: 31st May 2011, 14:59
  3. Which diesel engine??
    By cornishtaz in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2010, 17:39
  4. which diesel engine?
    By Pigman1 in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2009, 22:59
vauxhall vectra 2.2 diesel only revs to 2500 revs
vauxhall 3.0 not revving past 2500rpm
vectra c wont rev
vectra diesel wont rev
