Thread: Middle rear seat belt.
    Apr 2006
    Default Middle rear seat belt.
    Anyone had a problem where the middle rear seat belt has jammed. It seems to have locked and cannot be used.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is the seat in the securing mounts properly? There is an interlock that prevent use if the seat isn't properly secured. Try releasing the seat back and then pushing back firmly
    HTH
    Apr 2006
    The problem did seem to happen after I had dropped the seats forward. I will investigate and report back, maybe I damaged the interlock.....
    The seatbelt works on an Inertia lock.... if the seat has been dropped forward the locking pin may have stuck in..... just release the seat and give it a bit of a shake and this should cure it.
    Its similar to the problem some older seat belts have when you park on a steeop hill and can't put the belt on cos the inertia pin has dropped into the lock because of the angle the car is at!!! A good shake should fix it!!!!
    Apr 2006
    Managed to sort the problem, there is a "stopper" fitted to the seat belt to stop the seat belt retracting to far, somehow the "stopper" had gone past the bracket of the seat belt, I had to undo the seatbelt from the anchoring under the seat, this released enough slack so I could force the stopper past the bracket, this cured the problem.
  1. middle seat belt locked
    By antowens in forum Bodywork & Interior
    Last Post: 8th December 2012, 16:45
  2. rear middle seat belt stuck i can help
    By callum in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2012, 12:26
  3. Rear middle seat headrest
    By Casper85 in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2012, 20:07
  4. rear middle seat belt not pulling out?
    By lubo_tl in forum Bodywork & Interior
    Last Post: 21st September 2011, 13:47
  5. Signum rear middle seat won't move back up !!
    By cav595 in forum Bodywork & Interior
    Last Post: 17th March 2007, 22:50
