Page 1 of 16 12311 ... LastLast
Results 1 to 10 of 158
Thread: Changing Auto Transmission Oil
    Devon
    Default Changing Auto Transmission Oil
    Hi, I've just bought I vectra 3.2 GSI (2003) and am new to these forums.
    I want to change the auto transmission oil (it's an AF33). Can anyone tell me please, if I can refill the box using the green dipstick hole or do I have to refill using the Filler Plug (or does it not matter which). There seems to be easier access to the green dipstick hole so I'm tempted to use that. Also is it really necessary to use new seals when refitting the drain/fill plugs?
    Thanks in advace for any help anyone can offer!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Haynes manual, which doesn't cover the GSi specifically but does cover your AF33 gearbox, says do it through the filler plug. Don't ask me why but that's how I did mine.
    Just a point to bear in mind, I put 0.5lt more than what they say in Haynes, to get the correct level on the dipstick.
    Have you got the oil yet? If not, here's one option http://www.partsforsaabs.com/product...oducts_id=3454.
    Also have a look at this thread http://www.vectra-c.com/forum/showth...light=93160393
    HTH
    EDIT - I used the same seals.
    PM me if you need any more info, only 20 miles east of you.
    SCOTLAND
    I have the 2.2 (04) auto and am now worried as i've done 73k and have never checked the autobox oil ? Sorry for the thread hijack but how do you do it?
    london
    Default Re-2.2auto tranny
    You need to check and renew the oil.it's well over due. The correct oil is ATF 3309/T-iv. Also used in saabs. I think change interval is every 40k miles. Do more seach on here as the topic has been covered. Thanks
    Regular Member poves's Avatar
    lancashire
    Either get the fluid from vx or saab , no other grade is correct.
    Use the filler plug on top of the box with the torx head to refill , use some pastic hose and a funnel to assist you .
    Check the level afterwards with the engine running and selector in park , hope this helps .
    Devon
    Thumbs up
    Thanks for all your help guys!
    SCOTLAND
    Thanks for that info i'll have a look at mine next couple of weekends if i get the time off.
    Nicking Ya Dinner.
    Hangon lads, I could be wrong, but generally a VX autobox needs the bottom plate taken off to drain the oil, and you should replace the filter and check for filing's, also you can't do a full change as some oil remains in the rad and pipes, and the method for checking the level is normally done with the engine running and a bung plug in the side, might be different on this box, but be careful it's a costly mistake if you get it wrong.
    lancashire
    Ehh ?
    Nicking Ya Dinner.
    Quote Originally Posted by poves View Post
    Ehh ?
    I'm just saying to be careful and not guess the procedure bud as it will cost an arm if it's done wrong.
  1. Vectra C auto Transmission Identification
    By kiwiscole in forum Engine & Drivetrain
    Last Post: 29th September 2012, 13:03
  2. Auto transmission starter motor
    By Lao in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2012, 13:41
  3. Auto transmission dipstick....
    By bigmac22 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2010, 01:34
  4. '03 Signum V6 auto transmission problem
    By Arnie in forum Engine & Drivetrain
    Last Post: 8th June 2009, 20:00
  5. Engine `spanner' light + auto transmission problem
    By omega2498 in forum Electrical & ICE (including SatNav)
    Last Post: 25th July 2007, 21:38
af40 gearbox oil
vectea c automatic transmission af33 fill plug location
af33 atf dark brown
vauxhall automatic gearbox af22 valve body price
af40 transmission oil change
af22 gearbox oil recommended
draining my transmission fluid z19 dth
gearbox oil level check AF406
oil aw1 for vauxhall
af40 gearbox oil change
af22 gearbox upgrade
