Thread: P1191 - fuel rail pressure sensor circuit low input
    Regular Member L11Marc's Avatar
    May 2008
    Liverpool
    Default P1191 - fuel rail pressure sensor circuit low input
    The other night my Vectra 2.2 Sri Direct (55 reg) was working fine, then as I was parked up waiting for a mate with the engine off, I started it again and the Spanner light come on, then went off, by this time the car lost power to 3000x revs and took its time to get upto 25mph, by this time too the engine light was on. Flat as anything, been told most Vauxhalls go into limp mode to get you home or to a garage.
    Today limped it to a garage, cost £20 to hook it up to the machine & its come back with code ''P1191 - Fuel rail pressure sensor circuit low input''...this was from a back street garage. So took it too lookers Vauxhall, they are going to hook it up tomorrow (£88 + vat) and if the 1st garage was correct going to cost £62.50 + vat for the new sensor + fitting, this sound a right price or time to shop around? Is it easy to fix yourself? Or any recomendations in Merseyside area. thanks.
    Quote Originally Posted by L11Marc View Post
    So took it too lookers Vauxhall, they are going to hook it up tomorrow (£88 + vat)...
    They're going to charge you £88 + VAT to hook up the Tech 2 and tell you, possibly, the same fault code as the other place? Is that all they're charging you the £88 + VAT for i.e. to read the fault codes and 'diagnose' the fault? If so, it's expensive and I'd take it elsewhere.
    Is the independent guy not able to do the work for you? - if that's what's needed.
    May 2008
    Liverpool
    Well its a bit complicated, Vauxhalls have told me im best getting it checked with them, obviously their going to say that but my only worry is if i leave the check with Vauxhall's and just order the part from them that when I go back the other garage more parts may be needed.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    will need a fuel pump and preshure regulator ... do a serch on here sounds like the same problem most the 22directs get at some point in there life
    That sounds expensive
    Yeah, I can understand that - you'd hope/expect Vx's diagnosis to be correct (although we all know they often aren't! lol) but £88 + VAT for a Tech 2 session (if that's all it is) is gobsmackingly expensive. Have they actually told you what you'll get for the £88 + VAT?
    May 2008
    Liverpool
    Theyve told me the £88 + VAT is just for diagnosis only. Then £62.50 + VAT for the sensor, then fitting on top of that, watever that will be so roughl£230 inc. VAT all in. But as the above said I need a 'fuel pump' & 'pressure regulator' the independant garage told me I just need a Sensor (part no. 24418424) so I dont no what to do, just try 1 part or fork out £88 for Vauxhall's to do their check...?? suggestions...
    newcastle upon tyne
    have u got any service history mate? Maybe u could argue that the same job has just been done and its only lasted 2 mins, if u got a receit that is. if not let that garage fit a new fpr (about £80)and if that doesnt fix it you will have to splash out for a fp (£lots£). sounds like the pump to me.
    May 2008
    Liverpool
    No service history, only had it since December. Got the diagnosis done today, it needs a new fuel pump which has been ordered, paid the £88 diagnosis fee & the bill for part & fitting is £426 + VAT.
    Ive read up on this and apparently its a common problem with the 2.2 Petrol Direct engines. BBC Watchdog done a programme on it in Jan this year.
  1. Prefacelift V6 CDTi Rail Pressure Sensor
    By smitd004 in forum Engine & Drivetrain
    Last Post: 6th February 2011, 18:05
  2. Oh no - P1191 - Fuel Pressure
    By nibblitz in forum Engine & Drivetrain
    Last Post: 13th October 2010, 21:38
  3. Fuel Rail Pressure Sensor - another thread
    By Stevo2 in forum Engine & Drivetrain
    Last Post: 30th June 2010, 20:52
  4. Fuel Rail Pressure sensor
    By RobW in forum Engine & Drivetrain
    Last Post: 3rd December 2009, 16:55
  5. V6 Diesel - fuel rail pressure issue
    By Phil in forum Engine & Drivetrain
    Last Post: 5th August 2009, 22:08
p1191
p1191 swift diesel
P1191 swift
swift railpressure
p1191 dtc swift
p1191 vectra 07
dtc code p1191
p1191Dtc
vauxhall zafira p1191
Maruti Suzuki swift tabal cod P1191
p1191 vauxhall vectra
vectra c fuel rail sensor
p1191 fault code
vectra fuel rail pressure sensor
VAUXHALL VECTRA FAULT CODE P1191
Vauxhall DTC P1191-52
p1191 vauxhall
Opel DTC P1191-52
p1191 fuel rail pressure sensor circuit low input
Vauxhall DTC P1191-5a
Ritz Fidel turban cord p1191
vectra fuel rail
low input vectra c fuel rail sencor
