Thread: help please regarding a clatter
    Regular Member robk6112's Avatar
    Halifax
    Default help please regarding a clatter
    Ive got 104k cdti 150 sri and after revving the car when stationary there is a clatter. If I rev the car with the clutch depressed its not present any ideas- it drives fine though...
    Halifax
    anyone....
    Admin plasma's Avatar
    On the Forum
    312 Post(s)
    Engine : 150
    Mileage : 74000
    do you hear the clatter once you take your foot off the accelerator? ie on the run down.. If so is probably the DMF (flywheel)
    Halifax
    yep on the run down- or no, do I just leave it as clutch seems fine?
    On the Forum
    312 Post(s)
    Engine : 150
    Mileage : 74000
    gonna be a fair few quid to replace that. Not sure on the long term effects other than being ruddy annoying
    Halifax
    I will leave it for a while and see if it gets worse then....
    Chelmsford
    Shaft bearings?
    Used to get it on my old Astra, clatter when the clutch was up, nothing when it was pressed.
  1. rear end clatter
    By volvodumper in forum Suspension, Wheels & Brakes
    Last Post: 15th May 2006, 19:27
