Thread: Please help, Heated seat stopped working
    leeds
    Default Please help, Heated seat stopped working
    Any advice would be appreciated as i have a2003 vectra that came with factory fitted heated seats, i have found that the drivers side heated seat no longer works, no lightr on the switch and no heat, i have checked the fuses in th boot and engine bay.
    Thanks.
    Surrey
    Check the switch, swap from the other side. Check under the seat as there should be a connector under there somewhere.
    Northampton, UK
    And if you still cant get it to work sell the pads to me LOL.
    leeds
    Quote Originally Posted by steve1975l View Post
    Thanks for the tip Steve ill give this a go.
    Sweden
    Papz: Can you provide some update on this issue? Have exactly the same problem... The connectror under the seat is a huge one and if you disconnect it without removing one of the battery connectors, the airbag light will stay on when you start up the car.
    Bristol
    I had similar issue with my drivers side heated seat. I swapped out the switch from the passenger side and it worked for a while then stopped. Closer inspection inside the switch showed that the main power track was lifting off the board and snapping. I suspect a short in the heated seat pad but VX have quoted £380 to replace both pads in the drivers seat.
    Sweden
    The switches are not interchangable from L/R but you can open them - and then the PCB can be moved from one switch to another.
    This worked for me. Now I have to wait for lower temperature to find out if the pads are working too.
  1. Heated seats stopped working
    By tox in forum Electrical & ICE (including SatNav)
    Last Post: 21st October 2012, 18:57
  2. Heated Seat not working
    By urbanfox in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2011, 21:52
  3. heated seat switches? also electric seat adjust questions?
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 11:48
  4. Heated seat not working
    By amos in forum Insignia car chat
    Last Post: 10th November 2010, 17:14
  5. Drivers heated seat not working - advice?
    By pgilc1 in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2009, 17:16
