Thread: Warning Symbol ????
    Newcastle
    Default Warning Symbol ????
    Just drove back about 15miles from the Metro Centre an hour ago & a warning symbol came up on the dash half way home, it was a circle with 3 curved marks on either side of the circle but nothing inside the circle at all. unfortunately i don't have a handbook but i've just downloaded one & it looks similar to the ABS warning symbol but without the 'ABS' inside.....any idea what it is ??
    Regular Member Psykadelik's Avatar
    London
    Bally, this sounds like the Brake Pad Wear Indicator symbol
    London
    Quote Originally Posted by BALLY View Post
    Front disc brake pads worn down to minimum thickness. You will need to check this immediately and have them replaced.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It is indeed the brake pad wear indicator, front left wheel is the only monitored corner. I wonder if it also is the warning light for brake fluid level too?
    They need inspecting soon, but you've probably still got a few thousand miles left before you get metal to metal contact (depending on your normal pad wear rate of course)
    Newcastle
    Thanks guys, i thought it might be that but wanted confirmation.....oh well time to book for some replacements in the next couple of weeks i guess !!
    Edit: Just been out again & no such symbol this time....Yay
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Ste, Brake fluid warning is the 'handbrake on' control lamp on the dash which should go out when you release the handbrake. Typically if illuminated when handbrake is off, check brake fluid level.
  1. Emissions warning symbol
    By johnnyw in forum Engine & Drivetrain
    Last Post: 4th February 2011, 09:19
  2. Anyone know what this warning symbol is???
    By n_hudson in forum Vectra C / Signum Troubleshooting
    Last Post: 7th July 2010, 10:46
  3. Warning symbol on dash HELP!!
    By parsco in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2009, 13:24
  4. Wots this warning symbol on the dash then?
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2008, 19:32
  5. Help Needed - Warning Symbol
    By trickydickySRI in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2006, 11:46
