Thread: Diesel fuel filter
    May 2008
    newcastle
    Default Diesel fuel filter
    Hi,
    has anyone changed a diesel fuel filter on a 109 cdti 120 vectra, if so is it a challenge or straight forward, the haynes book says you need a special tool to unscrew the top off. Would a strap wrench do the business.
    scotland
    or large mole grips/adjustable spanner.
    The element sits inside the plastic housing..easy to replace...bit messy though :-)
    I think guys have recommended new clips as the originals break on dismantle HTH .....
    Regular Member mattolly86's Avatar
    oxfordshire
    EASY JOB to do i used a strap wrench and i didnt need any clips
    May 2008
    newcastle
    Thanks for the help guys, Tadpole do you know which clips are prone to breaking, is it the ones that hold the fuel lines into the filter top ?.
    Quote Originally Posted by john1 View Post
    I was wrong, thinking of a petrol fuel filter sorry m8 ...........
    Regular Member GoldenWonder's Avatar
    Durham
    Is it possible to renew the filter element on the 1.9 diesel without removing the whole filter assembly? i.e just remove the pipes, unscrew the top and slot a new filter element in?
    Regular Member 30ltr nutter's Avatar
    dunstable
    if its the same filter as a 30cdti or a 20dti then u need a torque bit undo the bolt in the top remove pipes u need to close the clips up to remove pipes un plug sensor plug and lift the top of remove and replace filter and all orings that come in filter kit . fit new filter in housing and top up housing with fuel refit top and do up bolt refit pipes and start car but keep it reving until it runs ok then check for leaks . the reason u fill the filter housing is so u get rid of as much air as possible other wise u will need a hand primer to get it going
    Durham
    Sounds a lot like the 1.9 setup. Its topping up the filter thats the problem - I'll have to get a can of diesel from the garage or syphon some off from the tank!
    irvine ayrshire
    hi guys...sorry for jumping in but i have a filter for the 1.9 cdti 120 in my boot but i havent got a clue on fitting it. has any one got any photos or something on fitting the filter as i am in the same situation as the guy that posted this issue because i dont know where the clip is to take the housing off and have read a post a few weeks back regarding the price of a new one if you break it,not cheap....................
  1. Air in the fuel filter on 3.0 V6 Diesel - Help!!
    By NPS in forum Engine & Drivetrain
    Last Post: 25th October 2012, 18:25
  2. diesel fuel filter
    By jpdtm in forum Engine & Drivetrain
    Last Post: 6th October 2009, 20:59
  3. How do you drain the diesel fuel filter of water
    By chrisvectra in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2008, 11:04
  4. diesel Fuel filter
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2008, 21:18
  5. Diesel fuel filter
    By Trhains in forum Engine & Drivetrain
    Last Post: 28th May 2007, 16:44
diesel fuel filter drain vauxhall vectra 120 site:www.vectra-c.com
