Results 1 to 10 of 11
Thread: clunking noise
    Regular Member mark the hat's Avatar
    Jan 2008
    manchester
    Default clunking noise
    hi
    i have just noticed that i am getting a clunking noise just when setting off from standing,no noise when driving/changeing gear just setting off
    it's not very load but now i know its there its doing my head in i'm turning the sterio down just to hear if it's still their
    any ideas fellas.....?????????
    ive just had it lowerd could this be anything to do with it,a bolt worked a bit loose ?????
    engine mount?????
    cheers mark
    scotland
    is it a repetitive noise, or just a single clunk when pulling away ?
    Jan 2008
    manchester
    just a single clunk when pulling away sounds like its coming from the front of the car,and when you pull up a lights then set off again clunk,dosnt happen when slowing down/brakeing just when i set off........
    any thoughts of what it could be chaps ?????
    cheers mark
    Jan 2008
    manchester
    anyone ????????
    Jan 2008
    manchester
    off to the garage it is then.......
    mark
    Chelmsford
    Sounds stupid but it could be your radiator...
    I had exactly the same problem, horrible rattling clatter when pulling away slowly but not at other times. Spent ages thinking the clutch was knackered or I had a faulty engine mount.
    In the end I popped the bonnet up and started tapping things to see what made the noise, slapped my hand against the front of the radiator and there was a horrible rattle! Turns out that part of the plastic fan-surround (back of radiator, passenger side) wasn't supported properly and was banging against the metal. Got a small wooden wedge, jammed it between the metal and plastic and bingo, no more noise! Don't think the thing was actually faulty, just a bit of a crappy design.
    Jan 2008
    manchester
    cheers dns,i'll have to get under the bonnet when i get a chance and try that
    mark
    Regular Member Ben999's Avatar
    Milton keynes
    does it happen everytime you pull away, or just the first time?
    Jan 2008
    manchester
    hi
    everytime i pull away
    mark
    Jan 2008
    manchester
    and now i have found out today when i reverse setting off backwards flaming clunck,
    really starting to p me off now
  1. clunking noise
    By keggy77 in forum Engine & Drivetrain
    Last Post: 6th January 2012, 16:07
  2. New clunking noise, Yippee!!
    By oxenburger in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2009, 17:19
  3. Vec-B Help please, clunking noise or something!!
    By Vaux-Man-G in forum Suspension, Wheels & Brakes
    Last Post: 19th August 2009, 10:44
  4. clunking noise after pad change
    By blakewp in forum Suspension, Wheels & Brakes
    Last Post: 28th May 2009, 11:12
  5. clunking noise
    By big ron in forum Suspension, Wheels & Brakes
    Last Post: 24th June 2008, 19:04
