Thread: 52reg 1.8 sxi loss of power when hot
    Apr 2008
    Chester
    Default 52reg 1.8 sxi loss of power when hot
    Hi All,
    Got a problem with my 52 reg 1.8 vectra c sxi.
    In the week i travel about 8 miles to work and the car seems great, full power and nice to drive.
    At weekend or after blasts on the M-way etc when the car is nice and warn the problems begin. If i drive it at around 2k of revs it is ok but as soon as i boot it or drive over 2k revs the revs go mental (put foot down revs dip then waver a bit before eventually giving power) This can happen when doing anything from 20 mph - 70 mph in town driving or on m-way. Really annoying. At idle revs are ok.
    Car has 50k on it and I have recently had full service (plugs, oil change, air filter + fuel filter). The problem was there before service, got slightly better but now very bad)
    Any ideas what i can check / do before taking it to garage?
    Thanks.
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    IS it at wide open throttle mate if it is I had this problem on my corsa 3 years ago it turned out to be the MAF Mass Air flow Sensor get that checked out
    Apr 2008
    Chester
    any idea how i can check this? or any other suggestions
    thanks
    Apr 2008
    Chester
    I have recently bought a U480 and read the fault codes.
    This is the only code it found:
    P0036 - HO2S Heater Control Circuit (Bank 1 Sensor 2)
    Any one got any idea where i locate this sensor and is this sensor likely to cause the above problems?
    Also how much are these sensors, is it best to get a genuine Vaux part?
    Is it easy to fit the new sensor myself?
    Apr 2008
    Chester
    also a part number would be good, if anyone knows it.
    thanks
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. 2L DTI '53 Loss of Power
    By BigTunz in forum Engine & Drivetrain
    Last Post: 3rd November 2011, 17:27
  3. loss of power
    By rick1965 in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2010, 15:54
  4. power loss
    By genewilso in forum Engine & Drivetrain
    Last Post: 18th February 2010, 21:00
  5. loss of power
    By philly in forum Engine & Drivetrain
    Last Post: 11th May 2009, 07:21
vectra c 1.8 losing power when hot
